![]() | Home > Technical > Headlamp removing |
glenn Member Since: 05 Nov 2008 Location: Hampshire Posts: 26 ![]() ![]() ![]() |
Hi all I have had a look at removing the headlamps,got as far as levering up the two metal straps that hold them in place inspecting them to come out very easy,had a bit of a pull but nothing happened looking for some help Range Rover Sport HSE,Java Black,Allround Tint's, Black and silver badges,Black and silver wheel centers,Up graded leather,Brembo brakes,white side repeater lenses,led number plate bulbs,led side lights bulbs,led reverse lights bulbs, led interior bulbs,Front and Rear mud flaps. Looking for private number plate. black and silver front grill and side vents and replaced the boot strip with black one |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
you may have to juggle the metal slides up and down a bit to get them to free, when it does the lights slip out easily. I have to change mine over a lot, the hardest bit was getting the grill off |
Ok will give it another go ,so the lights should come straight out with out any force being used Range Rover Sport HSE,Java Black,Allround Tint's, Black and silver badges,Black and silver wheel centers,Up graded leather,Brembo brakes,white side repeater lenses,led number plate bulbs,led side lights bulbs,led reverse lights bulbs, led interior bulbs,Front and Rear mud flaps. Looking for private number plate. black and silver front grill and side vents and replaced the boot strip with black one |
As Alicat says - the metal slides need to be a little depressed, pulling them fully up doesn't align the headlight's mount. 2005 Zambezi TDV6 - Gone but not forgotten
OK sunday morning job |
All done headlamps came out really easy put led's in the side lights looks good |
Pictures please. How easy to install led's? 2005 Zambezi TDV6 - Gone but not forgotten
very easy pull out old bulbs push in new ones .Got to make sure they go in the right way or they don't work so I kepted the lights on to make sure. will take some pictures and post.Makes a big diffrence Range Rover Sport HSE,Java Black,Allround Tint's, Black and silver badges,Black and silver wheel centers,Up graded leather,Brembo brakes,white side repeater lenses,led number plate bulbs,led side lights bulbs,led reverse lights bulbs, led interior bulbs,Front and Rear mud flaps. Looking for private number plate. black and silver front grill and side vents and replaced the boot strip with black one |
I'm a numpty! |
Ok didn't fancy the led strip might look a bit naff Range Rover Sport HSE,Java Black,Allround Tint's, Black and silver badges,Black and silver wheel centers,Up graded leather,Brembo brakes,white side repeater lenses,led number plate bulbs,led side lights bulbs,led reverse lights bulbs, led interior bulbs,Front and Rear mud flaps. Looking for private number plate. black and silver front grill and side vents and replaced the boot strip with black one |
