Home > General > panel under steering wheel |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 |
Does any one know how to take off the panel under the steering wheel ? the one with the small vent in it.
Fri Dec 19 2008 8:03am |
SachaR Member Since: 13 Nov 2007 Location: Udine Posts: 508 |
RRS TDV8 HSE 2007- JAVA Black/Black interior, UK BMW M3 CSL SB- now sold 1968 Innocenti mini |
Fri Dec 19 2008 2:28pm |
Not sure if this will work...
Fri Dec 19 2008 4:35pm |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 |
crowej it just pulls off nothing behind there though, what you looking to do?? I had to remove mine today to find the fuse box but then looked at the manual and realized it is the other side to check a fuse, should have looked at the manual 1st. |
Fri Dec 19 2008 7:47pm |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 |
yup it just pull down and out from the top, the botto m has a superficial hinge that comes right out. i'm always behind that piece for my suspension settings... |
Fri Dec 19 2008 9:38pm |
I am wireing up a garage door opener, I have mouted the switch beside the light controls but need to route the cables down to somewhere to store the actual opener, I soldered the wires some wires into the opener that will activate it when the button is pressed.
Fri Dec 19 2008 11:33pm |
hmmm I'm interested my electric gates wont work with the oem butons, I'd like to see what you have. I always have to use this tiny looking car alarm remote to open up my entrence gate. |
Sat Dec 20 2008 3:06am |
