![]() | Home > Technical > Random Long beep ?? (warning) |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Just one bong / beep or does it repeat?? |
Considering your's a MY06, could it be the blasted PDC gremlin? |
You could be spot on there Bobby, mine has gone in today for this exact fault ![]() ![]() The computer said that there is a grounding issue, which I presume has come from the fact that they recently removed the rear bumper for paint. Its that or some other gremlin. ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
buckblue Member Since: 30 Oct 2008 Location: Lebanon Posts: 144 ![]() ![]() |
not sure about the pdc fault
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
If it is a PDC fault, it is a high pitched beep (a higher pitch than the normal PDC beep) that lasts about 2-3 seconds, and I think it originates from the rear speakers. Also, your PDC button on the center console should start blinking to let you know there is a fault in the system. It happens to me sometimes after a heavy rain or car wash when I engage reverse, evidently some water must enter one of the rear sensors, grounding it. After a few hours or so - as the water dries out, I guess - the problem disappears. |
Faulty ECU controller - on order, won't see that until the new year ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
guys the thing is the pdc button on the dash does not blink when the long beep comes on, just comes out of nowhere!
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
do have a dealer there or should i call someone of the Gandour family to help you out |
we do have a dealer, whats up with the gandour family? theyre good friends!
