![]() | Home > For Sale & Wanted > LED strips |
ROB SUTTON Member Since: 11 Dec 2008 Location: stoke on trent Posts: 10 ![]() ![]() ![]() |
Are these easy to fit as the lights appear to be a sealed unit? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Did you mean sick or slick .... ![]() What is the lettering across the bonnet ? (Hood) |
have you fitted them behind the glass of the headlight or are they on the outside? |
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 ![]() ![]() |
i think he did mean sick (but in a good way) ![]() Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
Did you mean sick or slick .... ![]() What is the lettering across the bonnet ? (Hood)[/quote] lettering is REVERE as in REVERE London these cats http://www.reverelondon.com/ similar to kahn or overfinch. They seem to be the classier end of rrs pimp'in |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
They fit on the inside, or under the headlamp between the bumper and headlamp. They literaly take a few seconds to hookup. and only a few minutes total to do everything.
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Have I understood you correctly that the LEDS only come on when you turn a corner? - I.E. Indicate to turn a corner (do they flash?) or when the side light is illuminated for turning a corner. 2022 P440e AB |
not really sure what your saying, however, when you turn the signal on with the control next to your steering wheel they turn on. they are just regular repeaters, just hooked up to oem ones...
