Home > Technical > help on using OEM bluetooth
buckblue
2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
my car seems to have the bluetooth and i have checked this on the LR website with my VIN number but when i go to the options to select bluetooth or connectivity its not there! help
also in the center console above the fridge theres a phone adapter stand but i dont know for which phone it is!
help!
Post #197775 Thu Nov 27 2008 11:19pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Turn your ignition key to position two, then use your phone to scan for blue tooth devices. Your phone should detect the car and it will show as Land Rover. The pairing code 2121.
I shouldn't worry about the phone docking point in the centre cubby box lid, you need a special phone cradle to fit in there and there are no cradles available for the latest mobiles. Infact Land Rover don't even fit the docking point any more, everything is done via bluetooth. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #197798 Fri Nov 28 2008 11:17am
PauloAmore
Scotland
You don't need to be in position 2 to pair... do you?
- I can pair with the car running but it can be a bit flaky. 2022 P440e AB
Post #197799 Fri Nov 28 2008 11:29am
TB
By position two I meant that the ignition needs to be switched on. It doesn't really make any difference whether the engine is running or not. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #197803 Fri Nov 28 2008 11:36am
