![]() | Home > General > 12V POWER INPUTS (CIGARRETTE LIGHTER) NOT WORKING??????????? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Fuses - behind the glovebox maybe? TB or Bobby may know more |
Yes, try the fuses in the glove box... Malaysia Boleh!
SILVER DOLLAR Member Since: 04 Nov 2008 Location: UK Posts: 44 ![]() ![]() |
Ok I will - do you know which number fuses correspond to the 12v inputs? GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
The info should be in your manual.
In the manual it says that Fuse number 19 is the auxiliary power socket for the centre console - do you think that will be for both the front and back as there is a separate one for the one in the boot? GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
..er.. how about fuse #55? Malaysia Boleh!
Oh yes great. I'll try that in the morning! Weird how both dont work though huh? GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
Got new fuses and working - lovely jubbley!!!!! GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
Cheers Bobby! GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
terrieremery Member Since: 07 Dec 2008 Location: devon Posts: 35 ![]() ![]() ![]() |
mines exactly the same never worked from new ,havent bothered with warranty yet as we dont use it |
