Home > General > WARNING!!! Windscreen replacement
ChrisP
Popped it back to the dealer this morning now clipped back in securely,thanks for all the advice guys. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #192970 Fri Oct 24 2008 9:42am
Sheffield Jase
England 2008 Range Rover Sport TDV6 HSE Java Black
150MM crack appeared in my windscreen today , where do you recommend I go to have it replaced competently? 08 HSE,5%TINTS, Factory tow bar, brum ,brum
Post #196372 Sat Nov 15 2008 8:07pm
from what I remember only a LR dealer can do it. 2005 Zambezi TDV6 - Gone but not forgotten
Post #196377 Sat Nov 15 2008 8:30pm
MAW
I had autoglass under insurance.... Confused
Watch them though..
Post #196380 Sat Nov 15 2008 8:52pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Even if you decide to take your pride and joy to the dealers, they will call out Autoglass to do the job for them. But at least you will be safe in the knowledge that they will ensure that the outer a posts are secured correctly and there is no damage to your bodywork. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #196402 Sun Nov 16 2008 8:20am
jmm
France 2008 Range Rover Sport TDV6 HSE Tonga Green
About windscreen, I have an awful wind noise coming front the lower left end ( you know in front of the driver in ''normal'' countries Whistle ) starting at 50 KM/H and getting worse when speed increases.
Any idea?
BTW it's NOT raining here so no leaks Laughing Whistle
Post #196405 Sun Nov 16 2008 8:47am
TB
It could be broken clip at the bottom of your outer A post. Try giving it a wiggle, it should be secure and there should be no gaps between the screen and the thin rubber seal on the inner edge of the A post.
Another couple of potential causes are:
a) a gap between the wing mirror cheater and the door. Check that the wing mirror trim is fitted flush to the door.
b) the window seal could be tucked in on itself along the leading edge of the door creating a little hole that the wind whistles into.
c) it could be down to the alignment of the front door to the front wing. If the door is outboard of the wing it could create the wind noise you mention. To check for this just place the edge of a bank card across the gap between the wing and the front door. The door should be slightly inboard or at most flush with the wing. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #196417 Sun Nov 16 2008 10:09am
jmm
Thanks a lot TB.
1/the windscreen is secured and there is no gap between the lower seal and the A pillar.
a/ I noticed a very slight gap between the wing mirror cheater and the door (1mm at the most)
b/ checked OK.
c/ It's flush.
I also noticed that the main rubber seal around the windscreen is not really ''sticking'' to the lower part of the windscreen. Is that normal?
Otherwise after checking all the seals around the doors I did not saw anything obviously wrong.
Post #196550 Mon Nov 17 2008 11:34am
