Home > Technical > Funny sound on startup!
gables
Ireland 2006 Range Rover Sport TDV6 HSE Zambezi Silver
I posted a query on this a few weeks ago but oddly got no replies! When I start my Sport it seems to activate the suspension height. It continues for about 10-15 seconds and then stops. I have the ride switches it the correct position. Has anybody else had this happen or is it a normal part of starting?
Post #19549 Tue Mar 21 2006 5:30pm
Tim in Scotland
If your Sport has sat unused for any length of time (weeks rather than days!) the air suspension loses it's air and the compressor will pump it back up to the set height when you start up. The suspension on mine creaks quite loudy when I activate the suspension, doesn't matter if I am going up or down it still creaks. The other thing you will notice is if you do this at night you will also see the headlights trying to self level as the suspension adjusts. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #19550 Tue Mar 21 2006 5:35pm
gables
Hi Tim,
No, I use my Sport every day and it happens every time I start.
Post #19552 Tue Mar 21 2006 5:39pm
Tim in Scotland
Sounds like a trip to the dealer then! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #19554 Tue Mar 21 2006 5:41pm
Bobby
On older RR models this will indicate an air leak in the suspension.
Usually, when the car is parked overnight, it will just settle down and adjust to a comfortable height but the air reservoir will be full. On start up in the morning, it will quickly get up to a proper height.
If this takes very long, it would mean the reservoir is empty (or nearly empty) and it's filling up before adjusting to the ride height. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #19575 Tue Mar 21 2006 11:52pm
When mine was a bit younger the suspension used to strange things on turnoff & startup (it used to drop a few secs after taking the key out etc) but it doesn't seem to do this anymore... Never a dull moment owning a LR! Wink
Post #19597 Wed Mar 22 2006 9:08am
Josh
As I had initial probs with the suspension warning lights and after a discussion with my local garage I've taken to locking the car in access mode when I park up before turning the engine off. This seems to have stopped the warning light fiasco. Dealer said the cars brain was constantly trying to level even when off and the only way to switch it off was to lock it down. My drive slopes down slightly.
Therefore when I start up that should give the compressor a minute or more to top up.
Just an idea might work for you. TDV6 - gone
TDV8 - gone
Post #19659 Wed Mar 22 2006 10:22am
