![]() | Home > General > Does anyone else get a driveline shunt at low speeds?SORTED! |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 ![]() ![]() ![]() |
I have an '07 TDV6 HSE. No drive line shunt, just the annoying rattle from the dynamic response system. Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Diablo Member Since: 28 Jan 2008 Location: UK Posts: 40 ![]() |
Gents,
Good to hear Diablo... |
cowey101 Member Since: 17 Jul 2007 Location: Gods country! Posts: 403 ![]() ![]() ![]() |
55 reg HSE, 31000 miles, low speed shunt problems too |
ROB.T Member Since: 21 Nov 2006 Location: LEICESTER Posts: 10 ![]() ![]() ![]() |
Had same shunt problem for over two years 06 HSE 33000 miles ,Do you think dealers would exchange information on fix. |
dai748 Member Since: 08 Feb 2008 Location: Wales Posts: 8 ![]() ![]() ![]() |
In LR speak = characteristic or inherent part of the car
enzojunior Member Since: 25 Jun 2008 Location: Sydney Posts: 26 ![]() ![]() ![]() |
My dealer said, "normal". He suggested that when these cars cruise along off-throttle, they put themselves into neutral to save petrol. So what is happening, if that is the case, is the gearbox re-engaging. Wierd?? 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack... |
Enzo I think your were told the first thing that came into the service managers head............................... when the car is cruising on a light throttle then the fuel ECU reduces and can even stop the fuelling to save fuel, the gearbox doesn't go into neutral 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
dustin Member Since: 02 Sep 2008 Location: Norcross, GA, USA Posts: 2 ![]() ![]() |
This clearly feels like a transmission firmware calibration issue. The transmission mechanically is probably okay. Its likely that the shift points (shift schedule) and torque converter lockup schedule were not properly calibrated from the factory. I feel the same thing on my 2006 Range Rover Sport. It feels like the transmission is "hunting" for a gear.
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
its a know prob with the 6 speed ZF auto gearbox - i had it on my former 2 Jaguars and on a friends BMW 7 but never had it with the RRS |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
I had one of those "software updates" at my last service having specifically mentioned this issue and TBH i haven't noticed it reoccuring since. |
afewbeers Member Since: 02 Mar 2008 Location: here and there Posts: 21 ![]() ![]() ![]() |
I have complained about this every time the time car has been in to the dealer for other matters (9 times now!). The gearbox has been re programmed etc but it has not made any difference.
I have had mine sorted but feel that this isn't the solution to everyones problems. My driveline shunt was huge but I have now had the rear drive shafts replaced and my RRS drives like new again. |
