![]() | Home > Technical > Poorly 2005 2.7 HDV6 HSE |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
First thoughts are a split turbo hose. I think this would explain most of the faults mentioned, but I'm no mechanic so dn't take my word as gospel.
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Sounds like an EGR valve has gone faulty / sticking, becoming quite a common problem as they get sooted up with horrible black gunge..Take it to the dealer to see what fault codes are showing.Will probably need to replace one or both egr valves. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
bluebarchetta Member Since: 18 Feb 2007 Location: Aylesbury Posts: 10 ![]() ![]() |
I'd go with the EGR value too. My D3 had exactly the same symptoms on Thursday.
See. . . I told you it was a faulty EGR vavle. |
Oops. It looks like I've got a touch of Jayitus . . .
