Home > Technical > Timing Belt or Chain
roobybaby
Hi all - csn anybody confirm what the TDV6 and TDV8 uses - belt or chain? I've been looking around and get mixed answers. Im hoping its not a belt for lots of reasons Shocked
Post #193393 Tue Oct 28 2008 1:20pm
I believe they have a chain. 2005 Zambezi TDV6 - Gone but not forgotten
Post #193405 Tue Oct 28 2008 2:17pm
Belt on the TDV6, chain on the TDV8.
Changing the belt on the TDV6 is a right old kerfuffle by all means... Confused
Post #193441 Tue Oct 28 2008 3:00pm
I stand corrected. Thumbs Up 2005 Zambezi TDV6 - Gone but not forgotten
Post #193442 Tue Oct 28 2008 3:01pm
roobybaby
thanks guys - its sort of what i concluded. i believe on the TDV6 it has two belts, one on the front and other on the back?? which the engine has to come out to change Rolling with laughter sounds like a very expensive job Shocked
Post #193505 Tue Oct 28 2008 9:03pm
BigMart
Hi Roobaby,
The one one the front is the timing belt , changing it is no big deal , you might need a mirror and patience but no worse than lots of other cars.
The one on the back is the diesel pump timing belt (i think....correct me if wrong).
If it breaks the worst that can happen is the car stops and wont restart.
YES it's a pig to change because you must remove the engine from the car or lift the body off the gain access.
Its only a matter of time before somebody finds a way around this but no-one has yet.
I was hoping you could move the engine forward 4-6 inches (props off , mountings off) and have enough access.
Anyone already done it ??
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #193508 Tue Oct 28 2008 9:55pm
