Home > Technical > 2 Stroke oil in Diesel engines? Has anybody read this? |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Hi 2nd
Sat Oct 25 2008 5:24am |
blackwood Member Since: 24 Mar 2008 Location: scarborough Posts: 6 |
Hi Guys,
Sat Nov 15 2008 9:45pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
you should add the 2 stroke before the fuel as this helps mix it into the fuel |
Sat Nov 15 2008 10:46pm |
Hi, Yes, you're right, I actually did that,though wrote it slightly differently.. I realised after I'd clicked "submit" D'oh!! |
Sat Nov 15 2008 10:56pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
I was at Penrite Oils last night to look at some of their historical car collection, and to listen to a man in the know talk about their products - oil etc!
Wed Jul 22 2009 6:57am |
In the UK I wonder what HMR&C would think about doing this. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Jul 22 2009 7:09am |
As a fuel additive - on which full tax would have been paid at the point of purchase - I don't think they'd care what you put in your diesel?! |
Wed Jul 22 2009 7:19am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Well what will that be, 250000Km instead of 300000? At about 15000 Km/year will have to replace it before 2025 then..... '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Wed Jul 22 2009 11:14am |
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 |
I have been using 2-stroke semi-synth oil since getting the RRS, and I believe it makes a difference. When/if I forget to add oil in the mix when I tank up, I immediately can hear and feel it. Especially in the colder months it was obvious and even now in the summer-time, I really can notice a difference.
Wed Jul 22 2009 11:21am |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 |
Im probably barking up the wrong tree here............ BUT YF states that it helps your turbo by keeping it lubricated. Now stop me if I AM heading for the wrong tree here but how would it do this if youre adding the oil to the fuel? The fuel shouldnt be going through the turbo as its bearings are fed from the sump. All the turbo does is compress the air heading into the engine, NOT the fuel! There shouldnt be ANY diesel in the turbo at all. Im sure if Ive spotted something wrong here someone will put me right? Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Wed Jul 22 2009 3:51pm |
SteveWilliams Member Since: 05 Aug 2007 Location: Swindon Posts: 138 |
I must admit I would try adding two stroke to an older engine but would be to worried of any possible damage it would cause to the RRS.
Wed Jul 22 2009 4:48pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Good point. I think ultimate diesel has enough additives in it to keep your engine clean. That's what I use. Personally I think it's too risky.....but each to their own TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Thu Jul 23 2009 1:52pm |
High quality semi-synth 2-stroke oil does the trick. And, it could never hurt your engine. Actually I know of someone who used this in a pinch, when there was no diesel around, and only petrol. He added 2-stroke oil in with the petrol, and used that mix in his diesel engine. It worked fine.
Thu Jul 23 2009 3:38pm |
Hi All, Well I'd just like to add that I'm currently running a 2007 3.0TDi Audi A4, and add the two stroke to every tankful, the car goes great on it and is noticably quieter. I only use Shell diesel, and several mates also put it in their fairly new cars, and have reported exta quitness, better economy and a smoother drive.. If it's that bad why do the Mercedes factory use it when testing their new motors? Can only speak from my own experience... Guess it's only like using that lovely "gold top" diesel that you get in France...
Sat Jul 25 2009 4:14pm |
