Home > Technical > Rinspeed Lowering Module |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 |
I've installed a Rinspeed lowering module and was wondering if anyone on here has as well? i have a few questions if so. Thanks
Sun Oct 12 2008 7:07am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Cool any pic's before and after? RRS TDV6 Gone but still around
Mon Oct 13 2008 8:36am |
Frosty_Power Member Since: 02 Oct 2008 Location: Calgary Posts: 93 |
did u do the install yourself? i just inquired and they mentioned that it would cost me 1800us plus install time. pretty pricey but looks good. the ride is not bouncy at all? how do you control the unit? there was no write up when i asked for a brochure. |
Wed Nov 12 2008 7:06pm |
Yes I did the install. No the ride is not bouncy and corners much better because it has a lower center of gravity. The unit is controlled by two pins that you have to use a small flat head screwdriver to turn. Each turn is about 1mm. after making the adjustments you just raise your vehicle up and then all the way down for the system to take the new settings. I love it, my vehicle always hase that aggresive look being lowered at all times. A lot of people have commented on how they like my RR over others because its not ridding way up in the sky when its actually moving; I have to agree and its exactly my reasoning for purchasing it.
Fri Dec 05 2008 5:34am |
ROK Member Since: 28 Feb 2011 Location: Westside is the bestside Posts: 21 |
Hi MO, I just got my Kahn 22s and considering lowering about 1" at normal height. There's been a lack of good threads about this here and elsewhere, but perhaps it's my lack of skills along the web search front? -Rinspeed LMs are the same as the Mansory LMs, right? Mansory bought Rinspeed, IIRC. -All I want is the LM to just lower the factory "normal" ride height setting by about 3/4 to 1". Everything else, I want the same settings and function as stock. -Does the RR adjust height at hwy speeds? If so, does the LM nullify this so it stays at the new lowered "normal" height setting regardless of speed? -Did you get a new alignment after you lowered the normal height given that camber will likely change? Thanks, all! |
Mon Feb 28 2011 3:48am |
