![]() | Home > Technical > Side Mirrors Not returning to position |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
If your vehicle is a MY06 or 07, there is a TSB (number LTB00042 here in N America) that should take care of that issue. The short term fix is to turn off Lazy Entry from the Settings menu, the permanent fix involves replacing the driver seat module. Some sort of software conflict in the original seat modules causes the dipped mirrors to act up if you have Lazy Entry enabled. As long as your vehicle is still under factory warranty and within the VIN range, the control module will be replaced at no charge. |
bob242 Member Since: 13 Jan 2008 Location: France Posts: 39 ![]() ![]() |
yep u need to have the seat memory module chaged but the problem will come back at some point.
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Thanks will get it checked out ![]() |
