Home > Technical > Gearbox staying in 4th gear too long
enzojunior
Australia 2006 Range Rover Sport TDV6 HSE Java Black
I do quite a bit of country driving and recently I've noticed that, even when running on a flat road section after a hill of overtaking, the gearbox stays in 4th for what seems to be far too long before dropping into o'drive. Has anyone else experienced this? Got a fix? Is it an issue? 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack...
Post #187034 Sat Sep 06 2008 2:48am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
enzo some chat about similar problems on here http://www.disco3.co.uk/forum/topic24467.html
head to the stealers and get it checked
Cheers Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #187037 Sat Sep 06 2008 4:40am
vogue se
Belgium 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Ask at your next visit to the dealer for a remap.
And try to be gently with the trottle. When it doesn't change, reduce pressure on trottle a little bit and it will change gear. Wink
RRS stays longer in a lower gear then the D3.
Post #187054 Sat Sep 06 2008 3:15pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
The box has 6 gears so are you sticking in 5th?? The box is also adaptive so learns your driving style, perhaps it thinks you may zoom off any moment Shocked Very Happy Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #187283 Mon Sep 08 2008 9:01pm
enzojunior
Thanks for the tips. Had the gearbox remapped ysterday at my regular service. Drove 300km and still noticed it sticking in 5th. Pushed stick into manual mode and pushed "up" to 6th and it changed in. I'll give it some more time to bed down. Maybe the suggestion that it's "learning" is right. 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack...
Post #189393 Wed Sep 24 2008 3:35am
