Home > Technical > Sat Nav Voice Recognition
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
7 out of 10 times i get in the motor and turn the ignition the sat nav voice recognition kicks in without any buttons being pressed, the instrument display shows "listening" and the voice states "Sory command not recognised" this is doing my swede in and the dealer is checking with the factory as they do not know what is the cause, the other thing is that the voice recognition on the sat nav does not work and i have done everything as per the manual, has anybody else had same problem or does anybody know how to fix it. Big Cry
Many thanks
Post #182570 Tue Aug 12 2008 10:43am
Tim in Scotland
Voice recognition in my car was tried on the first afternoon and hasn't been used since!
Waste of time as it never seems to recognise any sort of dialect/accent - and I speak pretty clearly as I use radios a lot in my job and even then I cannot get the dammed thing to recognise my voice whereas the Ukranians and Filipinos who I work with and who's first language isn't English have no problem understanding my commands over a radio in plain clear English!! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #182573 Tue Aug 12 2008 10:50am
ViewWise
yea i only use it to show people how amusing it can be when you say one thing and she decides to do something else.
Post #182583 Tue Aug 12 2008 11:23am
I wonder if the voice control button is jammed in or something... it sounds like the car is expecting you to say something as soon as it turns on, which would normally only happen once you'd pressed the voice command button. Can you have a look at that and see it it can be "pinged" out with a cocktail stick or something? Confused
Agree it shouldn't happen in the first place Very Happy
Post #182584 Tue Aug 12 2008 11:24am
leedsunited
Dont think so as it is intermittent, it is a TDVS 06 HSE also had LR Bluetooth after market kit fitted as pre requisite of the deal and that is also doing strange things intermmitantly, wonder if the 2 issues are connected
Post #182618 Tue Aug 12 2008 12:14pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
I think you can be sure they are connected. I had an after market LR bluetooth kit installed on my 2005 TD V6 and it worked intermittently for the first year before going dead. Turned out the wiring was done badly from the unit up over the windshield to the microphone and the technician had managed to screw the sunvisor back in through the wires. You may also have button problems on your steering column. I complained about cruise control not working always and they took wheel cover off and fixed the buttons/wiring. Bring it back and ask them to check the wiring they installed. RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #182643 Tue Aug 12 2008 2:12pm
leedsunited
Many thanks i think you may be correct and i am booking back in to stealer and will ask them to investigate your points.
Post #182644 Tue Aug 12 2008 2:15pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I have an intermittent issue with my cruise button not responding, was just living with it, but on the basis of this comment will contact the stealer to get it looked at!
Post #182703 Tue Aug 12 2008 10:47pm
Bobby
I remember an old TSB concerning this.
The problem was a "component software error from the phone system manufacturer" and I think they needed to change the "Accessory phone module". Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #182715 Wed Aug 13 2008 12:29am
leedsunited
Just had a call from the stealer and you are correct the TSB describes the exact fault i am experiencing, now booked in for new Accessory Phone Module.
I will post again once fitted and let you know if fixed.
many thanks to all for the help on this one Thumbs Up
Post #183149 Thu Aug 14 2008 5:07pm
Bobby
Good luck! Thumbs Up Malaysia Boleh!
Post #183182 Thu Aug 14 2008 9:20pm
Nice... it's not the first time an aftermarket install has screwed the factory wiring Rolling Eyes
Post #183264 Fri Aug 15 2008 11:51am
Lookers Park Royal
I think Shmoogle is right, in so much that the VR switch on the steering wheel is giving out signals. Next time you get in and it beeps, say in a calm voice "Radio Help". If it responds with the verbal Radio VR help then you know the system is working but the trigger isn't.
Let us know how you get on as it sounds a curious one.
James Thumbs Up
Post #183274 Fri Aug 15 2008 12:06pm
leedsunited
James Thumbs Up
Thanks and car booked in for Friday so I will advise all re outcome. Thumbs Up
Post #184339 Wed Aug 20 2008 1:02pm
Tim in Scotland
Sounds like you didn't get the "Matthew our electronics guy" like they have at Charles Hurst do give you the low down on all the controls! IIRC my hand over of the Tdv8 lasted something like 2 hours of which 1.5 was going through all the gizmos and controls. And I still don't use the VR! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #184347 Wed Aug 20 2008 2:00pm
