![]() | Home > Technical > Dynamic Stability Control cutting in on long left turns |
pers1 Member Since: 22 May 2006 Location: Heggedal Posts: 35 ![]() ![]() |
My RR Sport car is fitted with DYNAMIC RESPONSE, I have just change the front ball joints after having problems with front suspension knocking noise !
Hoye Member Since: 15 Dec 2007 Location: Tvedestrand Posts: 20 ![]() ![]() ![]() |
15th December 2008: Sorry to say, but I had to inform the workshop again today that the problem still exist on my car. The workshop have been in contact with RR hotline several times but I am not sure if they will mange to repair this failure. Anyone out there with the same problem that have found a solution to it? |
just out of curiosity.. how did you figure the above? Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
mr_moped Member Since: 02 Dec 2008 Location: Cheshire Posts: 81 ![]() ![]() ![]() |
i had this problem on a BMW 330Ci a couple of years ago. Every time I went round a long sweeping bend the DSC would cut in and start breaking my front wheel. After several trips to the dealer and spending alot of hours trying to figure it out, it was finally sorted. The answer was a faulty YAW sensor under the drivers seat. For those of you who don't know what a YAW sensor is, it's the same device they fit on helicopters to stablise the giroscope effect. This is fitted to cars in the event of the car spinning out of control. Thought it might help! Good luck. |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
Mine cuts on on most bends. Must remember im driving a RANGE ROVER sport and not just a regular sports car |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
Yes we will have yaw sensors ( acellerometers) , I dont know where they are fitted.
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
Hi, Have just been told by my dealer that they will replace the ACE Block which is a module controlling the DSC system. I will let you know the result as soon as the worhave been carried out. ![]() |
If the yaw sensors and the dsc ecu are in the block then great....
You feel and hear it as the brakes turn on ! And if you turn off the DSC this want happen. |
Isn't this the DSC working? - as you know the system will stop the car by applying it's magic when it feels the car is about to lose itself. 2005 Zambezi TDV6 - Gone but not forgotten
In a very nice left turn on ordinary roads with speed not above 60km/h???. ![]() |
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 48 ![]() ![]() |
What was the end of This story? |
