Home > Technical > Brake Pads!!!
RRSSS
Bahrain 2010 Range Rover Sport Supercharged Nara Bronze
Brake Pads!!!
Hi guys, been a while since I've posted, thought I might pop a question out there..
Was driving back home earlier when all of a sudden a warning light came on the dash: Check brake pads!!
Now, i've only done about 14k kms (around 8.5k miles), so surely this can't really be the case?? I thought they were changed only after about 40k kms?
I'm sure some of you have encountered this before? If so, any tips before I bring it in to the stealers tomorrow?
ps. No, I don't drive around like a loonytoon out on a qualifying lap, so im sure i cant blame myself for this Whistle
ps. ps. apologies if this has been discussed before (most probably many times before... damn brembos!!!)
Post #179009 Mon Jul 21 2008 4:10pm
kam100
Have a read of this thread mate..
MAy be a different issue but may be the same thing, as you've done way too less miles to need brakes changing..
http://www.rrsport.co.uk/forum/topic10921-15.html
Post #179014 Mon Jul 21 2008 4:31pm
RRSSS
cheers mate, and thanks for reaffirming the fact that I've not done near enough miles to need a change..
much appreciated! Thumbs Up
Post #179053 Tue Jul 22 2008 5:45am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: Brake Pads!!!
First set at 19K KM's "which was nice" Rolling Eyes , second set have lasted 30K and not a problem so far and checked on the last service.. so i must have got caught first time around Evil or Very Mad .. about 320 Pounds on the current exchange rate to have them done Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #179082 Tue Jul 22 2008 9:41am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I had my Supercharged for 32,000 miles and didn't need to replace the brakes.
I have had my FFRR now for 14 months and 25,000 miles and am about to replace all pads and the front discs. The rear pads though were replaced under warranty last September and they are allready 75% worn. That almost makes a new set of pads every calendar year! OUCH!
Mind you, at least I can get the whole job done including parts for £200, bet you can't do that with a Sport! Very Happy
One day, I will learn how to do these myself, I used to do it on my Series 3, these should be easier as they don't have tricky to set up drum brakes. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #179086 Tue Jul 22 2008 10:01am
I got the 4 corners done for £230 inc VAT and I claim the VAT back! Thumbs Up 2005 Zambezi TDV6 - Gone but not forgotten
Post #179088 Tue Jul 22 2008 10:03am
RRUK
Dealer or high street? L319 D4 HSE
1982 Series 3 SWB
Post #179092 Tue Jul 22 2008 10:07am
LR approved bodyshop! 2005 Zambezi TDV6 - Gone but not forgotten
Post #179094 Tue Jul 22 2008 10:10am
RRUK
Not bad, but that didn't include any discs right? L319 D4 HSE
1982 Series 3 SWB
Post #179096 Tue Jul 22 2008 10:17am
All in, parts, labour etc. 2005 Zambezi TDV6 - Gone but not forgotten
Post #179097 Tue Jul 22 2008 10:19am
tafftoo
I did the rear pads on my sport a few weeks ago. EBC "Green Stuff" pads cost £43, new sensor cable cost £11. Did the work myself, and complimented on my workmanship when car went in for service. Took about an hour (including time sat staring at it). Gonna do the front ones (Brembos) in the next few weeks.
Post #179098 Tue Jul 22 2008 10:20am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
I paid fifty quid labour to have all four corners and wear indicators changed at my local garage just after christmas. Thumbs Up
Land Rover wanted nearly four hundred to supply and fit. Shocked Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #179140 Tue Jul 22 2008 1:45pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
... did you get the VAT back on the winch etc ? Surely such kit is wholly, necessarily and exclusively for use in the business of photography on the wild streets of Central London ..... Whistle RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #179179 Tue Jul 22 2008 8:41pm
RRSSS
Aargh, 200 Dinars for 4 new pads (around £265 to the laymans).. apparently they are all worn Question , couldn't be bothered to argue over the phone so told them to proceed.. It's the weekend coming and I need my RRS!
And they're going to clean up the discs again f.o.c. to reduce the squeeling (which will no doubt be audible again after about 5 minutes of driving)..
Through thick and thin i say..
oh by the way, was chatting with the mechanic and he had a pretty plausible reason for the squeeling. Ready?
He mentioned that previously, brake pads were made partly of asbestos. The companies then swapped it with some metal elements instead (as asbestos is dangerous etc). When driven, these metal flakes eventually gather together and when the pad is sufficiently worn, it makes contact with the disc, hence the noise. It is basically unavoidable.
Aaaaand, he had a possible solution: Get cross-drilled or slotted discs. Apparently this would cure the problem.. Sounds like he should be working with Brembo!
Ok rant over Razz
Post #179430 Wed Jul 23 2008 5:14pm
Didn't try - thought that would be taking the Michael! 2005 Zambezi TDV6 - Gone but not forgotten
Post #179434 Wed Jul 23 2008 5:31pm
