Home > Technical > Mirror Dip
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Mirror Dip
Ok, before I get shouted at, I have RTFM and still no joy Evil or Very Mad
Reversing mirror dip does not seem to remember its position. I have selected reverse, adjusted and then hit memory 1,2 or 3 and get a messaqge saying mirror dip stored. Place in neutral or Drive and then reselect Reverse....mirrors go all the way down Crying or Very sad
Any ideas or shall I enrol in numptyism Question Mr. Green L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #176267 Wed Jul 09 2008 7:56pm
MAW
I don't recall selecting reverse to store - functioned until turned off in settings as i recall - although i turned it of must mean that i wasn't impressed
could recheck in vehicle tomorrow... Confused
Post #176281 Wed Jul 09 2008 10:01pm
Bobby
Probably a silly question, but have you turned on the "REVERSE MIRROR DIP" in the "Settings Option"?
Also, did you store all 3 Memories for each Key? Here's the instruction:
Key 1
Turn Ignition ON.
Press memory switch '1' button.
Select Reverse Gear (mirrors move to 'default' dip position).
Move mirrors to required dipped position for Key 1 & Memory 1.
Press memory switch 'MEM' button followed by switch '1' button within 5 seconds. 'DOOR MIRROR DIP STORED' will be displayed on the message center together with a single chime. This is confirmation that the dipped position is stored.
Move mirrors to required dipped position for Key 1 & Memory 2.
Press memory switch 'MEM' button followed by switch '2' button within 5 seconds. 'DOOR MIRROR DIP STORED' will be displayed on the message center together with a single chime. This is confirmation that the dipped position is stored.
Move mirrors to required dipped position for Key 1 & Memory 3.
Press memory switch 'MEM' button followed by switch '3' button within 5 seconds. 'DOOR MIRROR DIP STORED' will be displayed on the message center together with a single chime. This is confirmation that the dipped position is stored.
Key 2
Repeat as above with Key 2
When 'Reverse Mirror Dip' is disabled via the Settings menu this clears all stored mirror dipped positions. When the function is next enabled new mirror dip settings will be required to be programmed as detailed above. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #176289 Thu Jul 10 2008 2:46am
MAW
You can always rely on Bobby - Thumbs Up
I seem to recall complaints about this on here somewhere though
Post #176295 Thu Jul 10 2008 6:31am
will_wonka
Thanks Bobby Thumbs Up
Unfortunately, have tried that and it just resets itself......could be an ECU issue I guess?! L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #176384 Thu Jul 10 2008 9:26am
ViewWise
does this mean when i put it in reverse and press any of the MEM buttons the pre stored setting shud automatically happen without moving the seat Shocked Shocked ? Would be useful!
Post #176416 Thu Jul 10 2008 10:56am
kljw
Scotland
hi,
after you have set you mirror position and stored it, select park, and press the preset buuton again (button 1, 2, 3) for the seat postion yu are in, do not push the mem buttion first. then select revers, i think you wioll thenm find that your mirros go to the position you have adjusted to, not sure why this is, but had the same problem with mine.
let us know if this works
keith
Post #176487 Thu Jul 10 2008 3:38pm
will_wonka
All sorted Thumbs Up
There were some error codes in the ECU or something....all cleared and does as the manual says now L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #176502 Thu Jul 10 2008 4:46pm
