Home > Technical > My Rusty RRS |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 |
I put the Stormers on my RRS last week & was quite surprised by the amount of rust on & around the brakes. Also some of the wheel nuts had some corrosion on them too.
Mon Jul 07 2008 8:37pm |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 |
I am not sure how to read the lack of response to my post.
Wed Jul 09 2008 7:28am |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
As with Rupert, the wheel hubs on ours look rusty but surface rust only (I hope!)
Wed Jul 09 2008 8:22am |
I think it's normal but that doesn't make it acceptable. It has been discussed before. 2005 Zambezi TDV6 - Gone but not forgotten
Wed Jul 09 2008 9:07am |
Julian Thompson Member Since: 21 Jul 2008 Location: Cheshire Posts: 12 |
As an engineer I would say that the BMW is likely to have alloy diff castings hence no rust but the RRS probably has cast iron instead which is obviously going to rust. Nothing to worry about though - that housing is so thick the rest of the car will be iron oxide before it gives a problem
Thu Jul 24 2008 8:21pm |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Has that BMW been driven in the same conditions as your RRS? I'm thinking of road salt during the winter etc?
Thu Jul 24 2008 8:28pm |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
also, just some thoughts, but are the BMW components using old part pre 'End of Life Directive'? Hex Chromium IV was used heavily in the past and gives great corrosion protection, wheres the forced replacements (Tri Chromium) isn't so good (or wasn't so good a few years ago when I was involved)
Thu Jul 24 2008 8:38pm |
Thanks all, I feel a little better now and will probably try to resist looking underneath in future.
Thu Jul 24 2008 9:18pm |
One other thing to mention - sometimes cars sit around for a LONG time (I mean over a year) in holding compounds post manufacture. I don't know if this could be the case on your RRS? If it's been sat there in the open for twelve months then that might have some bearing on rusting rates of the castings I suppose.
Thu Jul 24 2008 9:26pm |
