![]() | Home > Maintenance & Modifications > Smaller wheels for my RRS |
I think you'll find Alicatt has just masked his number plate out, leaving the year in |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Yep just masked out the number plate |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
The 19" RRS wheels turn up very regularly on Ebay and can be had for very little money (around £50 a wheel with poor tyres or £75 with decent tyres or £100 with new tyres). This is because so many RRS owners upgrade to 20" or 22" wheels.
dcc Member Since: 23 Jun 2008 Location: Channel Islands Posts: 32 ![]() ![]() ![]() |
Alicatt and Smoogle thank you for your replies. I am on my way now with confidence. |
R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193 ![]() ![]() ![]() |
Here are some 17's that they claim are for an RRS, if you're looking for small for the RRS then these would do the job |
There are 17" wheels for the RRS, BUT they won't fit on the TDV8 as the Brembo brakes are much bigger than the standard brakes, even with the Compmotive 18" wheels you still have to move the damper blocks so the wheels will fit. Sons of dogs come hither and get flesh
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Careful with those 17s, I believe the RRS "S" - unavailable across the pond, so someone correct me if I'm wrong - would be the only trim with brakes small enough to accept those 17" OEM rims. Factory SE and HSE trims mount larger discs and calipers that would not clear them, not to mention Brembo equipped S/C, TDV8 and HSEs with Dynamic pack where even OEM 18s are too small, as others already mentioned. ![]() |
