Home > Maintenance & Modifications > I need answers!
FAT_RRS
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
I need answers!
1. Is there a way to adjust the driver's side headlight to light up the road like the passenger's side does?
2. Are there aftermarket bulbs for our Xenon system which are brighter and more purpleish to blue (or the other way around)
3. If I cutt off the main resonator in the exhaust under the car, will it drone really bad? What if I cut off the mufflers and striaight piped them to nice tips? I want it louder, not too loud.
4. Largest tire size for 22's? I went to the local shop and he said the largest tire that would fit is a 285-35-22.. I'd like to go wider at least in the rear for a staggered fitment.. Will I be ok with at least a 10 inch wide wheel up front and rear?
Post #174282 Tue Jun 24 2008 10:55pm
1. Presuming the same logic applies in the US as it does in the UK, your offside headlight shouldn't ever be the same level as your nearside light. If you raise the level of the offside light you end up dazzling oncoming traffic.
2. Yes - do a search for various threads on this.
3. Don't know.
4. How large a tyre you can fit obviously depends on how wide the rim is. There are folks who have put 315s onto 22" rims, but they need a width of greater than 10" to mount safely really.
Post #174314 Wed Jun 25 2008 8:42am
FAT_RRS
I really like 315's... I would do a 10" rim as well. The 315's fit up front with no rubbing?
Post #174387 Wed Jun 25 2008 4:32pm
John @ DW
The 315s are no good for the front. If you want t he correct rolling radius you need to run 295/30/22 all round and the 285/35/22 is actually out. Most people fit the 285/35/22 for the extra side wall and comfort. If you want a really wide look go for a 22x9.5 front and 22x10.5 rear with 295/30/22 and 315/30/22, with the right offsets you will not get any rubbing. Something like the Myrtle Leons are great in this set up (see pic).
Post #175261 Thu Jul 03 2008 5:35pm
R33
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
and that photo is showing the absolute limit of the off-road ability of those wheels Laughing Wink
Post #175273 Thu Jul 03 2008 8:38pm
John @ DW
It was a struggle to get it all the way to the middle of the field, once it was there we needed a 110 to drag it out!
Lets be honest most RRsports never even see offroading as extreme as this!
Post #175274 Thu Jul 03 2008 8:54pm
R33
True true, looks nice though, I've never seen a D3 with 22's Bow down
Post #175285 Thu Jul 03 2008 9:52pm
John @ DW
The D3 actually really suits certain 22s, makes it look all Judge Dredd.
Post #175293 Thu Jul 03 2008 10:30pm
