Home > Technical > Where do the electrics Plug in for Towing?
flight
I recently purchased a thule bike carrier but I cant seem to find socket for where the electrics plug in....
Its probably staring me right in the face but dumass here cannot seem to locate the damn thing... LoL
Shocked
Please, can somebody enlighten me?
Thanks guys
Post #171581 Wed Jun 04 2008 1:42pm
Misery
Flight they are located under the rear tray, you have to use a screw driver to remove the cover but be prepared to replace the screw because the little Censored always seem to break. Hope this helps. Thumbs Up Thumbs Up
Post #171586 Wed Jun 04 2008 2:28pm
flight
Thanks....
Wheres the rear tray???
L Shocked L
Im terrible i know...
Post #171614 Wed Jun 04 2008 6:31pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Flight - Have a look at the following picture :
The "rear tray" is the plastic cover in the centre of the rear bumper bar - see the two visible lines to either side of the central cover. Can you see where the tow bar would be attached in the photo (visible red plastic insert underneath bumper in the centre) ? Just above and to either side of that tow bar area are 2 plastic circular screw heads. Use a large flat bladed screw driver (or a 10p piece) to turn each of those quarter of a turn. This releases the central cover - lift the bottom edge forward and off. Then the tow bar electric sockets are revealed - as long as you have towing electrics fitted. If these aren't already fitted, you can easily fit them yourself in about 30 minutes after buying the wiring kit from a LR dealer for about £100.
Thumbs Up RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #171618 Wed Jun 04 2008 9:15pm
flight
thankyou
Bow down Thumbs Up Bow down
Post #171639 Wed Jun 04 2008 11:36pm
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
If you mean the plug socket adaptors that go into the LR towing kit and feed the tow bar electrics - they are behind the nearside trim panel in the boot.
Didn't Alan M show us a picture of it. Have a look in his gallery. I am sure it was on one of his pics last year. You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #172207 Mon Jun 09 2008 8:55pm
theo
2007 Range Rover Sport TDV6 HSE Java Black
And be carefull with the f****** unbelievable thin plastic screws. I've used them 3 times and now I have 4 pieces..
Post #173337 Wed Jun 18 2008 8:33pm
Smarticus
The "secret" technique to use to avoid damaging these screw fittings is to only ever turn the screw after carefully ensuring the screw is correctly located and orientated in the hole and whilst applying lots of inward pressure to keep the screw in said hole. This is necessary to ensure the spade end of the screw fitting has cleared the edge of the receiving hole. If you try to turn the screw against the edge of that hole it will almost certainly break. RRS TDv8 HSE Rimini
Post #173369 Thu Jun 19 2008 6:51am
TheVerb
Australia 2010 Range Rover Sport SDV6 HSE Santorini Black
Electric/electronic brakes?
Does anyone know if the RRS fitted with factory tow kit can control a trailer (horse float) fitted with electric brakes?
Post #320241 Sun Nov 06 2011 4:24am
