Home > Technical > Rear Brake whine...
bt11
Rear Brake whine...
So this is the 3rd time I’ve had my TDV8 in now for a really annoying whine when i set off... seems to be coming from the rear drivers side wheel!
First time they said they would give it all a clean up.. That worked for about 10 mins Sad
Took it in again.. this time redid all the handbrake pots etc... Worked about 2 hours...
This time sat the Censored technician in and said listen you Censored get this sorted!!!
Been on the LandRover head Office and says they have had reports of 2007 models RRS all models squeak/whine noise caused by faulty brake pads...
Hopefully this will sort it out
Just wondered if anyone else has had the same??
Pick her up later so will let you know: thumbsup: Range Rover Sport TDV8 OVERFINCH ECU remap/tuned, 22" Satin Black Tigers, Black/Black, sideskirts, tints, clear ind, 09 upgrades +++
Plus others......
Post #171100 Fri May 30 2008 11:03am
bt11
All sorted... on closer inspection seems the sping on the caliper wasn't aligned or functioning correctly so this was causing the noise.
Hope this helps if anyone else runs into this issue Thumbs Up Range Rover Sport TDV8 OVERFINCH ECU remap/tuned, 22" Satin Black Tigers, Black/Black, sideskirts, tints, clear ind, 09 upgrades +++
Plus others......
Post #171112 Fri May 30 2008 1:38pm
