Home > General > indications on dashboard disappeared!!! |
You might find it was literally just one of those things... if it happens again, then it could be something faulty which your dealer will probably need to sort. But unless it happens again, I wouldn't worry too much.
Thu May 22 2008 12:01pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
S has it nailed with that diagnosis he used to work for LR you know Sorry S ..... |
Thu May 22 2008 5:16pm |
georgio Member Since: 07 Apr 2008 Location: Nicosia Posts: 21 |
I would appreciate if you provide me with some technical advice. Has this problem appeared to other cars also? RRS TDV8 HSE Java Black |
Thu May 22 2008 7:46pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
This is not a regular problem and is likely to be caused by a poor connection somewhere - probably in the plug from the instrument binnicle. The heat may have been a factor. If it does it again get your dealer to check it out. Just one of those things I'm afraid and could happen on any car. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Thu May 22 2008 8:03pm |
My view is that S can provide the comedy and the stealer is your best bet for the tech side...
Thu May 22 2008 8:30pm |
