Home > Technical > Key wont turn in ignition and hybrid tv cuts out a lot
tastech
Australia 2008 Range Rover Sport TDV6 SE Rimini Red
Hi
I just got my new RRS last friday...
today whilst refueling at the petrol station i went to restart and the key would not turn.
Gear lever was in Park and my foot was on the brake...i took out the key and locked and unlocked the remote
put the key in opposite (180 degree flip ) and finally it worked? I assume this must be related to some security feature??? or is it something else...cause i notice the GPS screeen stays on a for a short period after i have left and lock the RRS???
The other query i had was...the Hybrid tv cuts out a lot...I am in Sydney Aus...does anyone else in sydney or Aus experience the same thing??? I know get cut outs out home on the digital tv and i need to check the antenna cables reseat them and the cutouts go away?? is it a loose cable or just bad reception/weak antenna??
Cheers Toyota Corolla...Sad((((
formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse
Post #170058 Mon May 19 2008 12:27pm
D-Tech
England 2006 Range Rover Sport TDV6 HSE Rimini Red
Post #170069 Mon May 19 2008 1:23pm
tastech
D-Tech wrote:
Also try a slight turn of the wheel.
Rob
Thanks Rob that was the trick....it was the steering wheel lock...jiggle the wheel and the key spins...with all the
high tech in this car...i thought it was some electronics stopping it...
cheers
Steve Toyota Corolla...Sad((((
Post #170140 Tue May 20 2008 10:16am
