Home > Technical > Help. Can't pair phone with bluetooth, won't find LR device
cponce
Hi, have read all the manuals and forums, but the problem is that when I put py mone on discovery mode it will not find the integrated bluetooth phone on my car, (blackberry pairs fine with other equipment) but will not find the LANDROVER device), is ther a way to turn the bluetooth on/off? anybody has a clue? thanks
Post #169935 Sat May 17 2008 9:15pm
No the cars bluetooth should be on all the time and as far as I'm aware you can not switch it off. A trip to a LR dealer is my only advise. 2005 Zambezi TDV6 - Gone but not forgotten
Post #169949 Sun May 18 2008 6:55am
Have you tried to pair another phone to the RRS? RRS TDV6 Gone but still around
Post #169955 Sun May 18 2008 8:08am
joka748
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
There is a different bluetooth pairing code depending if your car kit was factory fitted or dealer installed.
The pairing code for a factory fit is 2121 but for a dealer fitted system (even a LR one) try 0000.
Hope this helps.
Post #170001 Sun May 18 2008 5:50pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Also depends on what handeset you are using......some are notoriously tricky. Shocked
It took me 20 mins to get the Iflone to sync with the Freeloader....but only seconds with the RRS !! L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #170017 Sun May 18 2008 7:56pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
I have a retro-fitted LR bluetooth system - have experienced this problem twice. I disconnect (-) battery connection for couple of seconds and re-connect and the bluetooth resets itself. RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #170053 Mon May 19 2008 10:47am
