Home > General > Front indicator problem - really peed off... |
Fuse? If not get it sorted under warranty. 2005 Zambezi TDV6 - Gone but not forgotten
Sat May 17 2008 7:57pm |
Diablo Member Since: 28 Jan 2008 Location: UK Posts: 40 |
It will go in under warranty. |
Mon May 19 2008 1:18pm |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 |
The probably broke a small metal piece that is welded on the bulb holder. it makes the connection between the circuit. If the little metal bead is missing from the holder thats your problem. Its common if you take your bulbs out a enough. |
Wed May 21 2008 6:16pm |
