![]() | Home > Technical > SEVERE PROBLEM WITH MY RRS.. |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
I think he actual accelerator stuck down.. in Bmw's the accelerator is on a hinge, either that got stuck, or it got caught on something..
Chris arrived early and phoned on arrival, i dashed back from a job and have just been through some items with him.
Now Kam I wonder of the 4 loaners offered which one you'll get. I bet you a fiver it's the focus or a gold Freelander. You could be really unlucky and get offered an Audi! |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
I know its only 9.30am Kam - but come on, is it all sorted yet |
KAM!!! You're a lucky lucky chap, I'd say. Glad you came out of it with nothing more than an increased heart rate |
Hi Guys..
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
wow u r really unlucky kam100 - i am just about to think to change my order into a 4.4 SE .... |
Zipperman19 Member Since: 22 Aug 2005 Location: South Florida Posts: 85 ![]() ![]() ![]() |
Kam
Sorry to hear you had the same issue as me, did your display say anything? Mine says 'special programmes off' and bonged everytime its done it. Is a bit of a worry,
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Kam, did you have the cruise control on? Like this site? Buy some RRSPORT goodies to show your support! |
Did the first two times this happened, thought it may be a pattern, i.e. use cruise control and it will conk out.. so on way back up north on sat, i was driving conventionally, foot on gas and it happened all the same.. |
My display said, "Engine System Fault." The engine did not turn off,but I had no power. I floored it and the gears shifted down but the RPM's were dropping. When I stopped the engine was still idling and I did not even try to accelerate. I just shut it on and off and it cleared. I've also got about 9500 miles on my car. I can't remember if crusie control was on or not. I know I had it on at one point but not sure if it was on at that moment. Anyways, I pressed the accelerator to pass at that point and then the engine just lost power. There was no shoulder one time, very scarry to be just rolling off the road. Other drivers looked clueless, even the one I had just passed. Note: Even if you turn cruise control off, it still semi-remains active and you simply need to press the + button on the speed to set it. So even though I may not have been activly using it, it was still in "Sleep" mode (does that make sense?).
You owe me a fiver VA.. Just remembered! |
I hoped you missed that one! Give it to you on the factory visit! Do you like your Volvo? |
