Home > Europe > can the side step be fitted after market ? |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 |
hi guys
Fri Apr 25 2008 1:37pm |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
Yes. Any dealership should be able to do it for you, or you can do it yourself (theres a land rover fitting guide floating around). Looked a bit complicated to me personally . |
Fri Apr 25 2008 1:41pm |
You can attempt it yourself, but as with a lot of these things it's easier to have someone else do it.
Fri Apr 25 2008 1:53pm |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 |
Do it yourself mate i did
Fri Apr 25 2008 5:26pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I know member Umbertob takes his steps off when he goes off road so can't be that hard to fit if he dose it so often RRS TDV6 Gone but still around
Fri Apr 25 2008 5:53pm |
its a lot harder to fit them first though Jay as you have to fit the brackets underneath the car and change all the side moulding trims
Fri Apr 25 2008 7:08pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
I thought the LR steps are dealer fit anyway, even if you spec them from new? Runner up - 2009 Best Avatar Award
Sat Apr 26 2008 9:59am |
They are RRS TDV6 Gone but still around
Sat Apr 26 2008 10:02am |
boyd Member Since: 29 Apr 2007 Location: at home Posts: 74 |
thinking is easy ...but getting these in europe, outside UK ...if you know where pls let me know |
Fri May 09 2008 7:24am |
Am I missing the point boyd, but can you not just get them mail ordered to you from wherever your nearest dealer is?
Fri May 09 2008 7:30am |
OEM LR side steps are easy to get at yr dealer for about 850 eur in Europe ,but for aftermarket ones you have to order them in the UK and postage is very expensive due to measurements,if they even want to send them to you.
Fri May 09 2008 8:17am |
Don't go aftermarket, go OE
Sat May 10 2008 1:26pm |
