Home > General > TDV8
bt11
TDV8
Afternoon all,
Just about to put deposit on 07 TDV8 RRS. Its done around 20k. Just wondered if there is anything in particular regardes it being a 2nd hand vehicle i need to look out for?
Cheers Thumbs Up Range Rover Sport TDV8 OVERFINCH ECU remap/tuned, 22" Satin Black Tigers, Black/Black, sideskirts, tints, clear ind, 09 upgrades +++
Plus others......
Post #166765 Wed Apr 23 2008 12:48pm
Leo
Kenya
Hi bt11,
Just make sure it's been serviced when it was meant to, has the latest software updates and make sure the suspension doesn't knock. In fact, ask if it's ever had that problem.
If you can, check the service records to see if it's been reliable so far, which would indicate it's not a lemon.
Hope that helps!
Post #166805 Wed Apr 23 2008 5:37pm
Yep, it needed a service at 15k so that should have been done by now Very Happy
Post #166881 Thu Apr 24 2008 10:59am
bt11
Thanx for the info guys.... had another test drive in it today< took everything you said onboard and also the post regarding knockin at low speed!!
Pleased to say everything was great< service when due< no knocking and amazing to drive Smile
Deposit payed pick her up sat morning Thumbs Up Range Rover Sport TDV8 OVERFINCH ECU remap/tuned, 22" Satin Black Tigers, Black/Black, sideskirts, tints, clear ind, 09 upgrades +++
Plus others......
Post #167064 Thu Apr 24 2008 5:08pm
woody
Hi..
I'd recommend a good look at the rear tyres. Mine are wearing very unevenly on the rear like a few other guys on here. Rear nearside is practically worn on the outer edge. Other than that... its fantastic!! Thumbs Up 2010 Discovery 4
2007 Suzuki GSXR 1000
1993 Defender 90SV
Post #167090 Thu Apr 24 2008 8:38pm
