Home > My Range Rover Sport > It's off to the Dealer for 2 days...
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
For the first time ever I let them pick it up, but only because I now know the driver well enough and have seen how he drives the cars, he's a good bloke.
I booked it in so they can look at a whole raft of things that were niggling me, but not problem enough individually to warrant it going in.
1. Clanking noise when reversing on full lock at access height
2. Logic 7 too muffly and bassy, needs s/w upgrade
3. Heater system needs s/w upgrade- poor flow, low heat on cold days and roasting feet all the time.
4. Knocking from steering column
5. Rear tailgate struts weak
6. Windscreen wipers make too much noise as they drag across the screen (still! Evil or Very Mad )
7. Poor cold starting
8. A much needed valet!
Not sure if I will get chance to update you when it comes back as we go on holiday the following morning, but will eventually of course (They have computers in Canada right?) L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #16319 Wed Mar 08 2006 10:07am
Zipperman19
United States 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
My dealer told me the struts were designed that way and new ones wont help in cold weather. Evil or Very Mad Evil or Very Mad God they area annoying
Post #16441 Wed Mar 08 2006 4:35pm
RRUK
I am fully expecting them to come back with replies like
"We couldn't replicate this..."
or
"We tested that and they all do this..."
The usual stuff you get.... Banging Head L319 D4 HSE
1982 Series 3 SWB
Post #16458 Wed Mar 08 2006 7:09pm
RRUK
I LIKE BEING WRONG
I just called the Dealer to check on the status (cos they never call you, do they? Sad )
Apparently this is where they are at with each issue:
They have ordered a steering shaft to cure this
Performed the Upgrade and it seems to be much clearer and less muffled
Performed the upgrade
as above steering issue, could be related
Ordered new gas struts to be fitted
6. Windscreen wipers make too much noise as they drag across the screen (still! )
Ordered me some new wipers to be fitted
Found a malfunctioning Oxygen Sensor, ordered it, also replaced a coil sensor.
I am pleasantly surprised that so many of the issues have been solved, even if it means I have to book it in again once I am back from holiday to have the steering shaft, sensor, gas struts and wipers fitted.
I am very pleased with their level of service. Well Done Stratstone Nottingham. Thumbs Up L319 D4 HSE
1982 Series 3 SWB
Post #16501 Thu Mar 09 2006 12:22pm
