![]() | Home > Technical > Annoying Rattle from Passenger Side |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Sounds like the sat nav unit as I seem to remember that is where you would have removed the disc from.
pTed Member Since: 04 Feb 2007 Location: South Posts: 9 ![]() ![]() ![]() |
Yep, I'm pretty convinced it's the sat nav unit, but it makes the same noise with no disc in place.
Do you have sill plates? I found that I hadn't stuck the drivers side one down hard enough and it was rattling on the underside of the door at speed on less than velvet smooth roads. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Nope, don't have sill plates. |
Check your external door trim - if this is loose it vibrates the faster you go and makes a sound like the one you've got. 2005 Zambezi TDV6 - Gone but not forgotten
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
just got back from ols so have missed thishowever I had exactly the same problem - take a look at your door trims at the bottom of your nearside door - they make this noise whenthey'e not pressed on correctly.
monkey9952 Member Since: 09 May 2007 Location: In A mess Posts: 163 ![]() ![]() ![]() |
Had this problem meself , untill i realised it was the wife |
Your wife was making a rattling noise? |
I assumed most women rattle on ? |
You can stop the rattling by buying a replacement handbag I think. |
Replacement? Don't you mean additional hand bag? RRS TDV6 Gone but still around
I suppose - replacing the one she currently has, which will get chucked in the back of the cupboard only to find that in two weeks time, she has to go back to it because the new one doesn't have enough pockets, straps and buckles. |
It's not really like that is it? Oh the joys of all i have to look forward to |
