![]() | Home > General > Need Land Rover Official Customer Service contact... |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
AJSG Member Since: 30 Dec 2007 Location: London Posts: 85 ![]() ![]() ![]() |
Forgot another bit...
That's taking the |
Spoke to a LR customer services person last week, basically they cannot transfer warranty work from one dealer to another if the warranty has expired in the meantime. Pretty ridiculous really, he said he is trying to contact Stratstone but the service manager never calls Land Rover back. Apparently they are going to give him some advice on how to solve my problems, unfortunately they can do nothing about his unprofessional attitude. Hopefully the recession will cure that... Tell you the truth, as much as I like the RRS I'm getting quite fed up with the marque...Audi is looking suddenly a lot more attractive... 2007 Audi Q7 4.2 FSI Grey/Black Int. 2005 Quattroporte Grey/Black Int. |
AJSG - Take it too the top. Customer services always try the fobbing off trick and excuses routine - there is no reason why you cannot use another dealer, all work is captured on the LR database. Be firm and set a deadline, from experience I do the following: 1. Customer dissatisfaction 2. Stealer contact (if applicable) 3. Fax to Customer dis......etc etc 4. Fax to Jonathan Edwards / Popham (if applicable) 5. Hard copy letter to the above (recorded) I usually bypass 1. Use 2. and then opt for 3,4 and 5 and TBH have had great results. It takes a while to cut through the red tape, but I seem to have it down to a tee now ![]() Good luck. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
NIM Member Since: 02 May 2008 Location: TORONTO Posts: 7 ![]() ![]() |
HI GET THE DEALER TO REMOVE THE FRONT AND REAR BUMPER ,WHAT IS HAPPENING IS I AM SEEIG A LOT OF SHORTED AND OPEN CIRCUIT IN THE WIRING , AND THAT IS 95 PERCENT PROBLEM WITH THE PARK AID SENSORS,ALSO FOR THE NOISE YOU NEED TO APPLY SOME ANTISIEZE PASTE TO THE 4 STEERING BUMP STOPS IN THE FRONT SPINDLE , AND THAT WILL CURE MOST OF YOUR FAULT, HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
