Home > General > Nokia N95 - Help Please
I had a Nokia in the cradle full time but now the Blackberry works I only have this. 2005 Zambezi TDV6 - Gone but not forgotten
Post #163126 Wed Apr 02 2008 9:25am
Robbi
Guernsey 2007 Range Rover Sport TDV8 HSE Rimini Red
shmoogle wrote:
There's a lot to be said for just getting a 6230 and keeping it in the car. This phone seems to work faultlessly, but then you could argue why should you need to do that.... Confused
Maybe a silly question but....can you have 2 SIMS for the same number. Like you say leave one permanently in the car. Rob
*Gone - HSE TDV8 Rimini Red + Tasmod sill plates
Post #163134 Wed Apr 02 2008 10:17am
As long as your provider does dual SIM packages.... last time I looked it wss only Vodafone in the UK that did this.
Post #163161 Wed Apr 02 2008 11:21am
ViewWise
I have since come to the conclusion that Robbi is right. I had it to auto authorise before and it refused to work properly all the time. Now when i get in the car i just manually connect to the car then press the phone button (and rotate the dial) on the car which prompts a message on the phone asking to allow the car, which i accept. Then it works fine Smile (although it does delay sometimes when i try and navigate the menus too quick).
Post #163253 Thu Apr 03 2008 8:16am
LJC
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Thanks for the 6230 suggestion and will talk to Vodaphone about a second SIM. If not an option do any of you know if there is a way to upload contacts from my Samsung D900 to the car memory? Bluetooth works fine so long as I dial from the phone. I also discovered if I press a single digit on the radio whilst in bluetooth mode it will dial the corresponding pre-set number on my phone!! Don't suppose there's a universal device to connect my Samsung to the RR cradle?
Post #163474 Fri Apr 04 2008 5:15pm
RR08
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
RR08 wrote:
I will give it a go in the morning and let you all know how I get on with the fix, if it works.
Emma
Having followed the advice and downloaded the latest software my phone now works with the car in blue tooth mode and seems all to be fine for the most part, though I still come across the odd glitch...
Wonderful stuff technology when it works.
Emma Range Rover Sport HSE TDV6 - 08 Plate
Post #163794 Mon Apr 07 2008 2:04am
Yes, you'll find it on the shelf over there next to the moons on sticks Wink
Post #163813 Mon Apr 07 2008 9:19am
