![]() | Home > Australia & New Zealand > Brembo Brake Pad Replacement. |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Wayne i had an original quote from the dealer on the service of $900 for all the lot, which i thought was pretty extortionate. I went back after 3 months (projected life of the pads) and they charged me 580, so make sure they are not totally taking the p155 Cheers Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Compuway Member Since: 02 Apr 2006 Location: Perth - Western Australia Posts: 57 ![]() ![]() ![]() |
Thanks Jim sounds very similar. I must admit that was probably 4 months ago now and I haven't been back. I was talking to another guy who specialises in LR and JAG servicing in Perth who said that when the time came, I should have a look at ordering the bits direct from OS as the prices here in OZ are plain exorbitant. Just thought I would do some comparisons as I don't mind changing them myself.
mp3madness Member Since: 25 Apr 2007 Location: AUSTRALIA Posts: 42 ![]() |
Wayne,
or perhaps SFP500070? |
Hey mate, how's it going.? Thanks for the numbers I have sent some emails off and will ring a couple of places tomorrow.
eastwop Member Since: 19 Apr 2008 Location: southampton Posts: 11 ![]() ![]() |
Top : Range Rover Sport : Brakes-Range Rover Sport : Front Brakes Supercharged-Range Rover Sport Code Description Price Quantity SFP500070 Front Brake Pads Supercharged-Range Rover Sport Front Brake Pads Axle Set for Supercharged-Range Rover Sport Important The Brake Wear Sensor must also be replaced when renewing Brake Pads �94.99 Axle Set SEM500090 Front Brake Wear Sensor late models-Range Rover Sport Front Brake Wear Sensor supercharged late models Range Rover Sport with Vin No 7A000001 onwards this item must be renewed when fitting new brake pads �13.99 each SEM500026 Front Brake Wear Sensor Early models-Range Rover Sport Front Brake Wear Sensor Supercharged Early models-Range Rover Sport with Vin No Upto 6A999999 Important This item should be also be replaced when fitting new brake pads �13.99 each SEE500080 Brake Pad Retaining Pins_Range Rover Sport Brake Pad Retaining Pins_Range Rover Sport �9.49 Per Axle Set SEE500040 Front Calliper Seal Kit Supercharged-Range Rover Sport Front Calliper Seal Kit Supercharged Range Rover Sport per Axle set �12.00 per axle set SDB000624 Front Brake Discs Per Pair Supercharged-Range Rover Sport Front Brake Discs Per Pair SuperchargedRange Rover Sport �54.99 Each SEB500090 Front Calliper Complete Left Hand Supercharged-Range Rover Sport Front Calliper Complete Left Hand Supercharged models Range Rover Sport �145.00 each SEB500080 Front Calliper Complete Right Hand Supercharged-Range Rover Sport Front Calliper Complete Right Hand Supercharged Range Rover Sport �145.00 each http://www.connectstores.com/lr/sp_37754.html hope this helps Terms & Conditions | How to Use This Store |
