Home > Maintenance & Modifications > anyone did a remap in Barcelona Spain? |
boyd Member Since: 29 Apr 2007 Location: at home Posts: 74 |
Pete from bellautos....Ive PM them but no answer...saw you edited yr message today PM them again with this address and lets hope I can get an answer soon...thanks again! |
Sat Mar 22 2008 10:05pm |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 |
I will send him a email now see if i can get an answer. Failing that , make a trip to ricardo@jcf4x4.es in Malaga ,Spain 0035 606403401 PM me your chassis number or registration number and ill make sure you get a very good deal/price for driving the length of the country. |
Sat Mar 22 2008 10:08pm |
thanks a lot pete ...but Malaga is about 1500 km away from Barcelona...
Sat Mar 22 2008 10:23pm |
Ahh , a bit to far to drive then
Sat Mar 22 2008 10:24pm |
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 |
@bellautos The TDV6 RRS 6-speed auto box does NOT have a maximum torque capacity of 472 Nm input. I have explained all this in a long post elsewhere which I can't be bothered to look for.Suffice it to say the TDV6 has the First Generation 6HP 26 box, or at best the hybrid 6HP 26A box, both of which are rated at 600Nm input. It does not have the 6HP 32, much less the 6HP32 A rated at 750 and 770 Nm respectively. Neither does the TdV8 which produces an LR stated figure of 640Nm so LR must think there is a very considerable safety margin
Sun Mar 23 2008 1:34am |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
I guess its not the engine or even gear box that comes under the biggest extra stress following a remap. Its probably the Turbo unit.
Sun Mar 23 2008 8:09am |
i stand corrected . I thank you for correcting me on this matter. |
Sun Mar 23 2008 11:52am |
np Peter, I am notorious at work for having told a Defender owner it would take 2 weeks to do a Stage 2 upgrade!
Sun Mar 23 2008 4:41pm |
I contacted Pete from Bellautos and he arranged me an ECU tuning ...right here in Spain Barcelona
Tue Apr 15 2008 8:35pm |
Hi Im glad your happy m8, The last car that had the exact same software revision as your car i had on a Dyno Dynamics dyno made 42bhp and 88nm only 4 or so weeks agao. "Yes more is possibile , but as you feel no more is needed" These are the figures id expect you to get considering your car is the exact same revision. How is the speed limiter going ? Did i hit the speed demod on the head with this one ? Regards pete |
Tue Apr 15 2008 8:45pm |
hey Pete,still not know about the speed limiter as the max speed allowed by the government is 80 km/h and on the highway 120 km/h... still could not pick a decent highway without cameras to check..will let you know!
Tue Apr 15 2008 9:40pm |
Hello Boyd, just a chq up on how your car is running,fuel consumption and your speed limiter.
Wed May 14 2008 10:10pm |
Hey pete,the car is running great...couldnt check for the speed limiter yet... will let you know asap |
Thu May 15 2008 9:23pm |
Hi
Fri May 16 2008 8:13am |
