Home > Maintenance & Modifications > Windscreen replacement
This topic is locked: you cannot edit posts or make replies.  Down to end
FYI -
1. Keep an eye out for any paint damage around the windscreen aperture
2. Whoever carries out the repair will have to use a wire to cut out the damaged screen. This should be a two man job so be suspicious if only one man turns up.
3. Make sure that they refit your outer A post trims using brand new trim clips. The clips are designed to be a single fit. If they re use the old clips you risk loosing them at speed.
Thanks to TB for this. 2005 Zambezi TDV6 - Gone but not forgotten
Post #160276 Mon Mar 17 2008 6:39pm
This topic is locked: you cannot edit posts or make replies.  Back to top
