Home > Maintenance & Modifications > Exhaust tip diameter on a TDV8? |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
The TDV6 pipe is 50mm and the SC bit is 60mm some as the TDV8 RRS TDV6 Gone but still around
Mon Mar 10 2008 4:50pm |
Jazzz Member Since: 08 Mar 2008 Location: Moscow Posts: 61 |
did the tips that you fund on eBay quote diameter or just said "s/c exhaust tips"? Cheers, Andrei |
Mon Mar 10 2008 7:08pm |
Yep the SC pipe is 60mm RRS TDV6 Gone but still around
Mon Mar 10 2008 7:27pm |
So the SC pipe is wider than the diesel pipe.... a previous post I found said they were the same (but didn't mention any measurements).
Tue Mar 11 2008 10:12am |
Well my guy had to make a bit for mine to fit in between the to told me the V6 pipe was 50mm and the new bit (SC) was 60mm just on going by what he told me RRS TDV6 Gone but still around
Tue Mar 11 2008 11:19am |
as I understood TDV8 pipes = SC pipes, and TDV6 are thinner. Cheers, Andrei |
Tue Mar 11 2008 11:35am |
TDV8 and SC = 60mm
Tue Mar 11 2008 11:36am |
So let me get this right. The TDV8 and SC pipes are 60mm diameter and the TDV6 is 50mm?
Tue Mar 11 2008 12:33pm |
Think so i'll have to double check for you mate!
Tue Mar 11 2008 12:40pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
TDV8 definitely 60 mm outside dia.
Tue Mar 11 2008 7:54pm |
I'm not saying it again RRS TDV6 Gone but still around
Wed Mar 12 2008 1:07am |
We shall never know then Jay Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Wed Mar 12 2008 8:30am |
looks like replacing the end part of the stock exhaust system with stainless tubing and welded-on chrome tips will improve both the sound and the looks.
Fri Mar 14 2008 7:31pm |
You mean with something like these:
Fri Mar 14 2008 8:02pm |
