Home > Maintenance & Modifications > Undoing mods
gothatway
United Kingdom 2006 Range Rover Sport TDV6 SE Buckingham Blue
Undoing mods
Two modifications to my newly-acquired RRS which I want to undo :
1) The chrome mirror covers. I suspect they were dealer fit (rather than after-market). Can they be removed without damaging the mirror surround ?
2) Light guards. The rear ones were easy enough to remove, but the fronts seem to require removal of the headlight unit - and will then leave holes in the grille surround. Is that right ?
Post #157845 Sun Mar 02 2008 9:18pm
You might be able to get the mirror caps off without any damage - all depending whether they were fitted normally or 'super stuck!'
Regards your grill - sorry to say there will be 4 holes left and yes you have to take the headlights out, which is very easy. 2005 Zambezi TDV6 - Gone but not forgotten
Post #157846 Sun Mar 02 2008 9:22pm
Tim in Scotland
The mirror covers may be held on with industrial strength double sided sticky pads like numbers plates are sometime stuck on with. Usual way to undo them is with a hairdryer to soften the adhesive, then you will have the problem of removing the marks left by the pads once the caps are off, but white spirit or turps should manage that. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #157849 Sun Mar 02 2008 9:50pm
Steve in germany
I would not try and remove the mirror covers if they where fitted by LR, the reason for this is they rough up the plastic before they apply the sticky stuff, hence might not be a nice sight once you get the covers off. Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #157850 Sun Mar 02 2008 9:51pm
Tim in Scotland
BTW if you don't want to keep the mirror covers after removal then you could stick them on the for sale section and donate the proceedings to the forum admin! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #157851 Sun Mar 02 2008 9:53pm
gothatway
Thanks very much for the speedy responses.
Maybe I'll contact the original supplying dealer to see how they would have fitted the mirror caps. My local dealer advised that I would probably need new mirrors (or possibly body-coloured covers); I had thought that might have been over-stating the situation, but maybe not !
As for the front light guards - guess I really need to find someone who wants some and to arrange a swap, complete with grill ! Is the grill easy to remove and refit ?
Post #157867 Sun Mar 02 2008 11:41pm
Tim in Scotland
Yes! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #157875 Mon Mar 03 2008 7:45am
hario69
headlamp protector
Hello
Sorry for being a pain - when you refer to the 4 holes in the "grille" do you mean the centre grille? I have just bought a RRS with the headlamp protectors but want to remove them and wonder what these 4 holes are going to be and where?
Thanks
Paul
PS how easy can you do this - I have seen that the headlamps need to come out but is that still true if you want to remove the lamp protectors AND front grille and just replace the grille with a totally new one?
Thank you Bow down
Post #206078 Thu Jan 15 2009 11:00pm
Yep you will have holes here is you can see?
Yeah you need to revers the job RRS TDV6 Gone but still around
Post #206104 Fri Jan 16 2009 12:08am
gothatway
Re: headlamp protector
Thank you Bow down
Yes, it really was very easy, and I found a ready buyer for the complete set of protectors and ready-drilled grille. I'm still left with the bling mirror covers, however Sad Sad
Post #206117 Fri Jan 16 2009 12:37am
A lot of folks stick their mirror covers on with No More Nails or whatever its called - you'll never get them off it's that's the case.
Post #206151 Fri Jan 16 2009 10:12am
