![]() | Home > Technical > Low Battery |
Think someone else said about this before but i'm not a 100% on this RRS TDV6 Gone but still around
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 ![]() ![]() |
i had the same message when i started my car the first time in a week.
JGreg1 Member Since: 04 Jan 2008 Location: Rogers, Arkansas USA Posts: 40 ![]() ![]() ![]() |
I've gotten this a couple times too, seems to only happen when I try to turn up the volume while on a call right after I get in. Or at least that's when I've noticed it. But it also seems to go away pretty quickly, so as cyberjes suggested, maybe the battery just needs to charge a little. |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
If the engine is not yet running, that's normal. Max volume is limited to preserve juice in the battery, so if you try turning the volume up beyond 20 (with the engine running you can go all the way to 35), a battery icon and "Low Power Mode" message will briefly appear on the radio LCD. |
exalld Member Since: 18 Mar 2007 Location: Camberley, Surrey Posts: 33 ![]() ![]() ![]() |
Thanks guys - as long as it not just me I feel better. Had the message again this morning when I put on the front and rear de-icer with high volume. I just need to learn to keep the volume down for that first minute. I need something to wake me up in the morning on the dreaded commute to work.
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
It also happened to me with a brand new car I tried to check the sound of the radio and the engine was switched off and it also appeared on the screen Max Volume Limited... so donīt worry |
