![]() | Home > Technical > Ipod question |
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 ![]() ![]() |
does anybody know if ipod connection in RRS is compatible with the first generation ipod? MY08 TDV8 HSE
Good question - I think it's compatible with all Ipods, although I'm not 100% sure. Someone will be able to confirm. |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
If the first generation IPOD has a 3.5 mm female jack on it, plug it in via a wire with 2 3.5MM male ends...should be a cheap test to find out. PJPR
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
Sounds like some couples I know ![]() Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
![]() ![]() ![]() Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock |
<OK---thatīs got to be a record...thread smartly derailed in 2 posts or less!
/PJPR01 thanks for trying. ![]() i use nano (3rd gen) as well. it's just that i do have a 1st gen ipod with bat problem that's lying around. Just thought it'd be nice to be able to use it. (or to use something that's actually made to fit the dock, if you catch my drift.) cheers. MY08 TDV8 HSE Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock |
SachaR Member Since: 13 Nov 2007 Location: Udine Posts: 508 ![]() ![]() ![]() |
I have a ipod photo 30Gb, it doesnt fit....... unless you remove the top clip as it is to thick to get in at an angle. I dont know if that helps.
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
there were a couple of adaptor plates came with the ipod dock, cant remember what they were for, they are still in the box at the house in belgium so cant have a quick look at them Sons of dogs come hither and get flesh
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
I found my 1st-gen iPod in a drawer tonight (remember when 10 gigs sounded positively ginormous?) |
/umbertob that's exactly what happened. i found out the hard way, as usual. i forced-fit it into the cradle but just didn't work. MY08 TDV8 HSE Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock |
Umbertob's right to get to all the function's on the ipod you have to use the docking cradle i.e track select, track name etc....
