Home > Tips & Tricks > [FAQ] Vent Removal....No Force Needed
ivery819
WARNING
Follow this entirely at your own risk!
THE VEHICLE
RRS TD V6 (MY late 2006 ) Australian Spec. Paint is 4 months old
TOOL
I used a very thin plastic or nylon spatula (that is sold in hardware stores) for applying top finishing coats on plasterboard joints.
I found that this tool did absolutely no damage to my paint when used gently and always moved only nearly parallel to the panel surface.
REMEMBER It is not a lever. It is only needed to depress the central tag in the vent clips.
THE SPATULA
EDGE OF THE SPATULA
THE VENT
To release the vent you need to release the 2 clips on the lower edge of the vent first 'A' then 'B'
The top clips will release by themselves later
detail of how the clips work (to release you need to depress only the central tag of the clip )
METHOD
Removal
Slide the tool nearly parallel to & between the fender panel and the lower rear outer edge of the vent as shown
Gently move the tool vertically up (ie. slide it further between the components)DO NOT USE AS A LEVER
A click will be heard (this is the clip releasing ) Gently hold the vent slightly out to stop the just released clip re engaging
Repeat the process with the forward clip
The whole vent can now be withdrawn with a gentle vertically downward motion.
Fitting
No tools needed
First engage the two top vent clips accurately in the slots in the fender panel.
Then simply gently push the lower edge of the vent inwards until the two bottom clips engage.
Check that the vent is secure.
Hope this is useful :D
Post #84624 Sun Feb 18 2007 3:33am
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Sure beats my "brute-force & ignorance" method that broke the tags off TWO SETS (replaced original HSE for S/C, then S/C for colour-coded pair). You'd have thought I'd learn from my first mistake.., but no! Thud Banging Head
Post #84625 Sun Feb 18 2007 3:39am
great tip Ivery Thumbs Up
Post #84633 Sun Feb 18 2007 10:07am
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
Excellent set of pictures with very good instructions Ivery Thumbs Up some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #84742 Sun Feb 18 2007 8:15pm
But what about this?? Sad
http://www.rrsport.co.uk/forum/topic2458.html RRS TDV6 Gone but still around
Post #84744 Sun Feb 18 2007 8:18pm
ENVOY
AARRGGHH but those pics dont show the clever little spatula tool, or it being inserted Thumbs Up some of my Previous cars
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
current vehicles
Audi R8 V10 Spyder
AC Cobra
Suzuki Jimney
Post #84757 Sun Feb 18 2007 8:35pm
Gekko
Your method's cooler. Cool Most of us are reptiles... only the enlightened few become human beings.
Post #139557 Wed Sep 26 2007 6:04pm
Mr. Green Thumbs Up RRS TDV6 Gone but still around
Post #140090 Tue Oct 02 2007 11:06pm
gazza500
Jersey 2008 Range Rover Sport TDV6 HSE Chawton White
yep, just fiited chromed vents. Removal and insertion a piece of p Censored iss, so were the vents!! Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Privacy Glass, 22 inch, Hawke Alloy Wheels, Brembo Front Brakes, Premium ICE Pack, Clear repeaters, Chrome Driving Light Surrounds, Tasmods, Chrome handles, HST Grille, Chrome Side Vents, JE ECU Upgrade
Post #140748 Mon Oct 08 2007 4:36pm
XUJG
JayMann great instructions. Once I managed the courage to pull it was over in seconds.
Thanks for your help.
The car styling chrome and java vents look the dogs Bow down
Post #143044 Sat Oct 27 2007 6:48pm
That's ok mate any time if you like them that much how about making a donation to help run the forum that will be more then thanks for me Thumbs Up RRS TDV6 Gone but still around
Post #143058 Sat Oct 27 2007 7:53pm
XUJG
yes will do JayMann
Post #143061 Sat Oct 27 2007 8:52pm
Post #143089 Sun Oct 28 2007 10:36am
Neilt
Absolutely brilliant, I was about to waste a Saturday morning removing wheel arch panels etc.
Well documented
NEIL THOMASjavascript:emoticon(':thumbsup:')
Thumbs Up Range Rover Sport; Ferrari Dino 246 GTS; Mini Cooper
Post #154126 Fri Feb 01 2008 6:50pm
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Great description! It didn't even take 10 minutes to replace both vents (including searching for the plastic ice scraper I used to pull them out)! No scratches or anything else, really great! Bow down
Thanks a lot. The Donation pays out so fast, I think I'll have to donate again in a few days... Cool
Post #197695 Thu Nov 27 2008 12:15pm
