![]() | Home > Maintenance & Modifications > Has anyone fitted the chrome mirrors? Need a little advice |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
The adhesive has its own part number at your friendly LR stealer, STC50551... And since it is not included with the mirror caps you purchased, it probably costs a fortune (if you must have the original stuff, google the above part # and you should get several hits of places that sell the tube.) I am sure you could get the same results with a small quantity of cheaper silicone / mastic-type adhesive from your nearby home improvement store.
trickas Member Since: 06 Mar 2007 Location: hants Posts: 53 ![]() ![]() ![]() |
grip-fill or no more nails
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Evo stik Wet Grab does the job |
Courtesy of MDP..
flight Member Since: 24 Jan 2008 Location: London Posts: 186 ![]() ![]() ![]() |
ThaNKS Guys,
It dosen't come in the box. They usually charge extra for the LR stuff with all the instructions in a foreign language just to confuse you. That's why I used the wet grab. TDV6 - gone
MDP did the same he didn't use the LR stuff either RRS TDV6 Gone but still around
Should have just used grip-fill? RRS TDV6 Gone but still around
Moral of the story is.......take the advice of those before you and use this stuff ![]() TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
L |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
