![]() | Home > Technical > ACC Automatic Cruise Control |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
Ok this is getting a bit frustrating now, my ACC see's things that are'nt there!!!, I can be cruising along say at 100/120mph and without warning, ie, nothing in front of me, the car applies the Brembo's which scares the |
I don't think anyone is a fan of it mate??? RRS TDV6 Gone but still around
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Yep happens a lot, especialy on righthand corners when you are over taking, I drive a lefthand drive TDV8, the ACC is in the same place on both RHD and LHD cars.
I've a vague idea dealers can disable ACC by turning off the module, but I don't think there's a user function to do so... |
If there is no option to switch the automatic off (either by the driver or the dealer) then maybe you could place something infront of the radar sensor mounted on the front bumper so as to block it from detecting objects ahead. This will disable it as and when you want to. Just a thought. |
Would that not send it into panic mode and slam the brakes on and ask for the driver to intervine? Sons of dogs come hither and get flesh Clan Cameron |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
I would have thought so. It would surely see the "something" as a VERY close object and either not work at all or apply the brakes. Paul RRS TDV8 - Stornoway Grey, Irory Leather with Dark Zebrano, Privacy Glass, Tow Pack. 1967 Cobra 427 S/C 1951 Vincent Comet 2001 Harley Davidson Fat Boy |
I don't think it will slam the brakes especially if you're just starting the vehicle, until and unless you're covering the radar sensor whilst driving at 100 MPH! But yes, you may be right. It will probably warn you of an obstruction at the sensor and deactivate ACC altogether. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
There are materials out there that absorb radar waves (rather than reflect them), so if you could find some tape or some such that didn't reflect the waves back again then there might be some legs in that. Where the hell you'd get such a thing I don't know - your local arms provider maybe? |
Baben Member Since: 14 Feb 2008 Location: Kyalami Posts: 29 ![]() ![]() ![]() |
Prestik or BluTack (sp?) works for the PDC, maybe it will work for the ACC too?
plum Member Since: 16 Sep 2007 Location: Heptonstall Posts: 39 ![]() ![]() ![]() |
If you cover the ACC sensor, the cruise doesn't work any more. I found this out last week when the ACC was covered in snow and it wouldn't switch on. it should have a switch really for just normal cruise. |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
Brave is the man who would want to use cruise control in thick snow |
Cruise control also dosn't work when towing. and there is a way to turn off the auto part of it, I dunno what I did but I did manage to get it off.
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 ![]() ![]() ![]() |
Surely this can be disabled by removing the fuse or relay for the ACC unit? |
