Home > Tips & Tricks > Bluetooth pairing code (2121) does not work
Ptang
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
On Friday I picked up my first Range Rover - a 2005 Sport HSE - and don't know why I didn't get one sooner Very Happy
However, here comes the usual newbie bluetooth question...
I'm trying to pair the car with my HP Ipaq PDA. The phone finds the car and requests the encryption key. I enter 2121 and it then comes back with a "incorrect key" message.
Is this a case of "just don't bother" or has anyone got an idea of why this does't work - from all I have read I haven't seen a way to change the car's key so that can't be it.
Thanks!
'tang.
Post #151698 Mon Jan 14 2008 9:44pm
Hi 'tang,
Mine worked with my old HP Ipaq PDA fine - the 2121 code should work
Post #151699 Mon Jan 14 2008 9:46pm
Ptang
Cheers Kaine,
I think it might be cause it's a 6915 mobile messenger - the PDA that isn't sure if it's a camera, satnav, computer or phone. No doubt HP screwed something else up when building it.
I'll pop the battery and try a hard reset to see if that helps.
'tang.
Post #151700 Mon Jan 14 2008 9:58pm
the main reason I stopped using mine - too many hard resets required
good luck Thumbs Up
Post #151701 Mon Jan 14 2008 10:02pm
joka748
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
Try 0000 and see if you get any further.
One of my un-resolved problems is that I can get pretty much any phone to work with 0000 but not 2121.
Post #151794 Tue Jan 15 2008 9:26pm
Ptang
Well, i just braved the rain to go try 0000 and you're spot on - it works perfectly.
Thanks for the info.
Post #151800 Tue Jan 15 2008 9:42pm
joka748
Did you manage to download your contacts to the vehicle system and dial numbers from the keypad on the radio? To download your contacts you need to be able to 'push' them via OBEX (object exchange).
Post #151803 Tue Jan 15 2008 10:27pm
Ptang
I've got the after-sale PTI so I only tested using the car as a headset. From what I've read in other posts I'm not even going to try pushing the contact as I'll only end up depressed when it doesn't work... Crying or Very sad
Post #151804 Tue Jan 15 2008 10:42pm
Yeah, the dealer PTI kit is a bit disappointing... didn't know about the 0000 code though, thanks for that! Thumbs Up I've shadowed this post into the Tips section with more meaningful title for future reference.
Post #151813 Wed Jan 16 2008 8:21am
