Home > Technical > New Member-RR Sport Aerial and Aftermarket Headunit
Sandy
Hi, I am new to this site- Nice site and very Interesting.
Could someone help me with a problem I have since I have fitted an aftermarket headunit to my RRS.
I have tried to connect the aerial but cannot seem to get any radio reception. I think the RRS has an Amp/booster but not sure if it does how to get it working.
I tried an old aerial I had to make sure it was not the headunit and that works fine.
Would be grateful for any advice.
Thanks- Sandy
Post #150625 Sun Jan 06 2008 6:58pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Hi Sandy - Welcome to the site.
The amp is fitted under the drivers (RH) seat. I'm not sure about ariel connections but this would be the obvious place to start.
Good luck and keep us informed. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #150626 Sun Jan 06 2008 7:41pm
Sandy
Thank you TB for your very quick reponse.
I have had a look at the amp under the seat but can't work out what goes where. When I connected the new headunit I disconnected all the RRS wires and re-wired all the speakers and power.
I think the orginal headunit had a "rem" conncetion to activate the aerial but do not know where to start.
I have asked my local dealer but no joy.
If anyone else has had a simlar problem I would be very interested to know.
My last resort is to mount a new aerial on the roof and connect directly. I don't raelly want to do this since I will have to remove headlining etc.
Thank agin for your support
Post #150628 Sun Jan 06 2008 8:13pm
TB
Try contacting Prestige Audio they are one of the site sponsors. I'm sure they will help if possible.
Check out the sponsors link at the top of the page. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #150648 Sun Jan 06 2008 10:43pm
Bobby
Could this be what you're looking for?
http://www.rrsport.co.uk/gallery/albums/us...ntenna.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #150653 Mon Jan 07 2008 12:56am
Sandy
Thanks again guys for all your support.
I will give Prestige Autos a call this morning and also see if I can remove the headlining to get at the Aerial box.
If it is ok with you do you mine if I can give you feedback on the out come for any other members benefit?
Cheers- Sandy
Post #150661 Mon Jan 07 2008 9:01am
Of course, Sandy... that's what it's all about. Good luck Thumbs Up
Post #150665 Mon Jan 07 2008 9:18am
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Would strongly recomend Prestige, for what its worth
They did a lot of work on my 996 targa (which is in there gallery somewhere). Workmanship second to none and incredibly pleased with all they did
Post #150720 Mon Jan 07 2008 4:04pm
Sandy
Thanks again for recommending Prestige.
I spoke to Chris one on the tech guys but he said they have never fitted an aftermarket system in a RRS. They have used the exsiting headunit and added various componets to it.
I should have spoken to him b4 I started- O-hum....
I think I am back at square one. Need another re-think this weekend. It looks like I will have to remove the headlining to fit a new aerial- Not looking forward to that since I think I will end up damaging something.
Post #150750 Mon Jan 07 2008 9:11pm
Bobby
Okay Sandy.
This might help you find the Amp connectors under your seat..
http://www.rrsport.co.uk/gallery/albums/us...er-ICE.pdf Malaysia Boleh!
Post #150754 Mon Jan 07 2008 11:04pm
stephenw
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Sandy, have a look at this. You will find other issues such as control of the message centre (resetting fuel consumption, changing the clock etc) when you replace the Headunit. It can be done but takes time.
http://rrsport.co.uk/forum/topic6085.html
Steve RRS TDV6 MY07 gone.
RRS TDV6 MY10 just arrived!
Post #150756 Tue Jan 08 2008 4:05am
Sandy
Thanks again.
Bobby do you have the references to the connectors on the amp- I am sure one or two of the wires will be the "rem" cable of the aerial.
Fingers crossed.
Stephen thanks of all the detailed info. When you put your headunit in did your exsiting audio aerial still work or are u using the T.V aerial to also work the radio?
One of my options is to have freeview T.V and DAB digital radio- Only problem is I won't be able to pick up traffic info.
Cheers- Sandy
Post #150769 Tue Jan 08 2008 9:28am
stephenw
Sandy, the existing antenna is used for AM/FM. The TV antennas (one on-glass and the one on the roof) feed directly into the TV tuner box which is mounted in place of the HK amp under the drivers seat.
Have fun.
Post #150770 Tue Jan 08 2008 9:43am
Sandy
Thanks again for all you help Bobby and Stephen.
Just to let you know I sorted the problem today.
Bobby's link to the radio amp was a just what I needed. Just added a "rem" cable after dropping the head lining and job done.
Thanks again- Sandy
Post #150921 Wed Jan 09 2008 8:56pm
Bobby
Glad it all worked out well. Smile
and Sandy, please thank RRSPORT.CO.UK too. Thumbs Up Wink Wink Malaysia Boleh!
Post #150926 Wed Jan 09 2008 10:28pm
