Home > Off Roading & Green Laning > Unsealed Roads |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
Texstar, I will let you know next time i take it out off road. When they put it on the diagnostics it came back with a fault code for the transmission and apparently there is a Technical Bulletin out for this somewhere. Once i get the paperwork from the stealer i can let people know what LR thought was the cause, and then see if the local roads prove them correct Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Sat Dec 15 2007 11:43pm |
Just a quick update, the paperwork arrived in the post from the dealer. The problem found with the diagnostics pointed to a faulty Transfer Case Module , which was replaced, not sure if it is the part number on the invoice, it states
Sun Jan 06 2008 6:16am |
I think Ron NorthWest was the engineer and that's his phone number
Mon Jan 07 2008 10:01am |
you could be right, but i reckon John West would have done a better job though excuse sir did you select 4wd.. Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Mon Jan 07 2008 10:43am |
Mon Jan 07 2008 10:47am |
