Home > Technical > Leaky RRS
Lateral5
Australia
Leaky RRS
I seem to recall this being raised previously, but I am a lazy arse....
When I popped into my dealer the other day to get my e-tag out of my petrol drowned diesel, I noticed a puddle of water on the passengers side mat.....we had some heavy rain the day before. I put my hand up behind the glovebox and I tapped a plastic part that seemed to be the source
Any ideas.....sunroof drains? RRS TDV6 Bluetooth, VR, Roof
Post #149873 Thu Dec 27 2007 11:57am
There's an aircon pipe that runs up the inside of the console, this has been reported to come loose before now and turn the footwell into a swimming pool. That's simply a case of reconnecting it, if that's what the problem is with yours Very Happy
Post #149874 Thu Dec 27 2007 11:59am
Lateral5
Australia
hmmm, thanks Schmoogle, but not sure it is the a/c. The car had not been driven for a few days (it can't be after my wife filled it with petrol Rolling Eyes ), so not sure why it would be the aircon drains? I have never seen it before even with aircon running all day......also, it coincided with the first decent hard rain we have had for ages.
I did do a bit of searching on previous threads and there is something about leak A pillars where trim fit holes leak. RRS TDV6 Bluetooth, VR, Roof
Post #149878 Thu Dec 27 2007 12:10pm
Sure, L5... it was just a thought Very Happy
Post #149879 Thu Dec 27 2007 12:11pm
Tim in Scotland
There have been a few leaks similar to this reported over on the Disco3 forums recently and it turned out to be the sunroof drains. IIRC there is a TSB out from LR about them for Discos 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #149883 Thu Dec 27 2007 12:15pm
Lateral5
Australia
Cheers mate Thumbs Up RRS TDV6 Bluetooth, VR, Roof
Post #149884 Thu Dec 27 2007 12:17pm
Lateral5
Australia
Thanks Tim, that's what the dealer thought too. RRS TDV6 Bluetooth, VR, Roof
Post #149885 Thu Dec 27 2007 12:19pm
Bobby
Lateral5 wrote:
... something about leak A pillars where trim fit holes leak.
This is the old bulletin...
http://www.rrsport.co.uk/gallery/albums/us...illar2.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #149893 Thu Dec 27 2007 12:37pm
Lateral5
Australia
Post #149939 Thu Dec 27 2007 11:46pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
This is a NAS bulletin on water ingress (it also refers to the bulletin posted by Bobby among the possible remedies, although in North America that TSB has a slightly different number than in ROW.) It makes our cars sound like a bunch of leaky buckets!
http://rrsport.co.uk/gallery/albums/userpi...ssrev1.pdf
Post #149941 Fri Dec 28 2007 2:50am
Lateral5
Australia
Thanks Umberto Thumbs Up , the fourth one down sounds like mine to a T! Have passed onto to dealer. RRS TDV6 Bluetooth, VR, Roof
Post #149942 Fri Dec 28 2007 4:04am
KiwiCool
New Zealand 2006 Range Rover Sport SDV6 HSE Buckingham Blue
Hi There Lateral5
Had a similar problem and thought I hadn't been using the aircon but that's what it turned out to be. Suggest you try that first. Fixed by dealer and no trouble since SDV6 (14.5) Corris Grey NZ Spec + door mouldings, mud flaps and tow bar
Also Audi A1 Sport + - (wife's rocket) and 1985 BMW 628 CSI
Post #149943 Fri Dec 28 2007 6:32am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
There are a couple of things which could cause this problem.
As everyone has already said the sunroof drain tubes could be blocked or mis routed.
Or it could be a leaking plenum seal. The plenum is the black plastic trim that runs across the bottom of the windscreen. A quick way to check this is to gently press on the black trim and look for movement or a gap to the screen which would let water through to the seal area.
From your description I think you can discount a leaking door seal or A post, these would normally show themselves via a wet carpet.
Good luck, I hope your dealer sorts the issue ok. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #149944 Fri Dec 28 2007 6:44am
Lateral5
Australia
Thanks lads, all very helpful.....the power of RRSPORT Thumbs Up RRS TDV6 Bluetooth, VR, Roof
Post #149945 Fri Dec 28 2007 7:43am
