![]() | Home > Technical > Service Interval Indicator |
TJ101 Member Since: 17 Jan 2007 Location: Somerset UK Posts: 207 ![]() ![]() |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Most of the 4x4 specialists have their own IDS now, give them a call its a quick and simple job.
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
You can try this reset procedure detailed on the Workshop Manual, although I could not get it to work on my 2006 Sport... I suspect the feature may be disabled on some markets:
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
I believe that it is an EU requirement for any old place to be able to reset the service indicators... Driven by legislative protection from having to use the dealer to maintain one's warranty (so long as the car is properly serviced)...
No tosh Paul,, truth in what you are saying,
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
On my MG you can reset the service indicator by shorting pins 1 and 8 on the OBD socket, it went in a sequence of three, short 1 and 2 would be oil service and the third would be for a full service, then it would cycle around again. Sons of dogs come hither and get flesh
Umberto - do you mind if I whip that post from rr.net and add it as a separate post in the tips'n'tricks section? That's info worth duplicating I reckon |
Hmm... well, he did say it might be market-dependent. |
At the moment it is market specific and in the UK its IDS or Autologic only
